Old 07-29-2005, 07:04 PM
hotwheels's Avatar
hotwheels hotwheels is offline
well hello david from belguim..........great to have you on board friend.......hotwheels
1992 mustang gt twinturbo'd
1988 mustang gt bottlefed
2004 mach 1 resting in garage
1989 mustang coupe 4 cyl.
1980 mustang coupe 4 cyl.
MY MUSTANG ENTHUSIASTS SITE
Insanemustangs
Old 06-14-2008, 04:31 PM
Macbuick's Avatar
Macbuick Macbuick is offline
Default Still alive...
and i have nearly all parts to start...
The wheels Salt Flat:
The brakes from BAER:
The Ron Davis Radiator:
The front lower and upper CPP tubular arms:
Old 06-14-2008, 04:32 PM
Macbuick's Avatar
Default suite
The rear upper and lower Edelbrock arms:
Quick ratio AGR power steering box:
A GS grill found on a Buick in a scrapeyard here in Belgium (the ugly) and a nicer, bought on ebay :
Old 06-14-2008, 04:33 PM
Macbuick's Avatar
Default again
A front bumper found in UK and the rear bought on ebay (there are no repro for Buicks!):
also, Dynamat isolator, a B&M transpak kit, a gearbox radiator, an Edelbrock fuel/air ratio gauge, ....
And i just went to order a P-1SC ATI Procharger from XS Performance with a 24"x12"x3" intercooler, an Aeromotive A1000 fuel pump, a Pro Flow bypass valve, an Aeromotive boost sensitive regulator, a Holley carb modification kit.
I will add to this:
a A-pillar pod for 2 gauges, a fuel and a boost pressure gauges, a Holley 650 carb, fuel filter.
I started to remove the old parts from the suspension to fit the new components and the brakes, in the rear i have to open the axle to install the Eaton LSD, I will place the supercharger as soon as i get it.
The car will be running before the big "restoration work"
Old 07-05-2008, 03:13 PM
Macbuick's Avatar
a little bit of cleaning to prepare the engine for the supercharger (trial fitting).
Out the drums and the old stock arms
[SIGPIC][/SIGPIC]
72 Skylark & 68 Pontiac Catalina+ 71 El Camino
Old 07-05-2008, 03:34 PM
Macbuick's Avatar
Default Copperage
[SIGPIC][/SIGPIC]
Old 07-05-2008, 06:08 PM
novanutcase's Avatar
Wow! What a nice car! Keep at it David! She is looking good!
John
Old 07-05-2008, 10:55 PM
WILWAXU WILWAXU is offline
Nice build up!
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
Old 07-19-2008, 03:34 PM
Macbuick's Avatar
Default help
Can someone tell me if the axle formed by the upper and lower ball joints has the right angle?
It seems that the caster is not quite good, is it normal, will it change when the car sits on his wheels?
The front of the car is on the left and the tubular arms are from CPP.
THX
David
[SIGPIC][/SIGPIC]
Old 11-15-2008, 08:01 AM
Macbuick's Avatar
Default Procharger
[IMG][/IMG]
[IMG][/IMG]
Here is the whole kit i received from XS Performance, including the intercooler...
also the side mirros and front hood chrome bought on e-bay....
[IMG][/IMG]
[IMG][/IMG]
[SIGPIC][/SIGPIC]
