Old 10-24-2007, 07:42 PM
clill's Avatar
clill clill is offline
I had one in the Red Witch with a aluminum 532" and it worked perfect. Never overheated even with the AC on.
Old 10-25-2007, 11:45 PM
tyoneal's Avatar
tyoneal tyoneal is offline
Wow!
Thanks for the confirmation and the recommendations.
Is the Correct Part number for the Fan, (Part-RF64)?
Where would you recommend buying these, and is there a specific Part Numbers for the optimum setup?
Mark VIII Fan
Get a 60 amp.
the best 10 gauge wire
Painless Wiring 190 degree 'on' sensor
DC Controller
Mark VIII Fan
60-75 amp relay
the DC controller
Yes, from what I understand it is running about 550 hp + I added a A/C unit not long ago. So I bet this is probably my problem
Thanks for all your input, if you wouldn't mind pointing me in the right direction for acquisition, the correct part numbers and what I might expect to pay for it.
Thanks again,
Best Regards,
Ty O'Neal
Old 10-26-2007, 07:57 AM
clill's Avatar
Measure from the tip of the water pump to the radiator and post the distance. Depending on what motor mount stands you have and short or long water pump you could have fit issues. Someone that has a setup on a car right now can post how much room you need. I know someone earlier had a problem so we should try to find out now.
Old 10-26-2007, 05:36 PM
69 L88 Camaro 69 L88 Camaro is offline
Originally Posted by camcojb
pullers.
Thanks for the reply Do you have a suggestion for a pusher type fan or fans? 1965 GTO, C&R radiator, BBC with roots blower drive. I was hoping to get the fan or fans ahead of the radiator.
I don't ride in it, I drive it.
Old 10-27-2007, 02:01 AM
tyoneal's Avatar
[QUOTE=clill]Measure from the tip of the water pump to the radiator and post the distance. Depending on what motor mount stands you have and short or long water pump you could have fit issues. Someone that has a setup on a car right now can post how much room you need. I know someone earlier had a problem so we should try to find out no
Clill:
I'll get the measurement tomorrow and post it here. I am also, very interested in sources for the correct parts.
Thanks a million.
Ty O'Neal
Old 10-27-2007, 08:06 PM
tyoneal's Avatar
[QUOTE=tyoneal]
Clill:
Thanks a million.
Ty O'Neal
Ok, here is the measurement.
From the tip of the water pump pulley (March System) to the back of the Radiator is right at 6 inches.
I look forwa to hearing from you.
Thanks,
Ty
Old 10-31-2007, 01:40 PM
tyoneal's Avatar
Thanks,
Ty
Old 10-31-2007, 01:45 PM
tyoneal's Avatar
To All:
Anyone else have any information regarding the fit of this fan?
Thanks,
Ty O'Neal
Old 11-14-2007, 01:51 AM
tyoneal's Avatar
To All:
Does anyone know if the distance of 6 inches between the tip of the water pump to the rear of the radiator would make it possible to install the Mark III Fan?
Also, Where would you recommend buying it and the accessories needed for a correct installation?
What kind of price can I expect to pay for it.
Thanks,
Ty O'Neal
Old 11-14-2007, 08:17 AM
JUSTANOVA JUSTANOVA is offline
Originally Posted by tyoneal
To All:
Thanks,
Ty O'Neal
I got mine from dccontrol.com and if i remember correctly the cut down version of the fan was 5 or 5.5 inches deep, I just looked up dccontrols website but it appears you have to email them, they used to have the products on the website. i got the fan and controller from them.
Project EARTHQUAKE:
72 Nova SS, Plans have changed a little:artmorrison front subframe, and rear 3 link, pretty much stock ls1 and six speed with a single turbo for around 550hp. with a few other things mixed in.
current cruiser: "The green machine"
'70 Impala 4drht, 26K original miles, 2" drop springs and large swaybars, drives pretty good for a land yahct
and why do we modify everything...."BECAUSE STOCK SUCKS"
