Old 11-29-2007, 07:47 AM
CRCRFT78's Avatar
CRCRFT78 CRCRFT78 is offline
They need a G-body setup.
Old 11-29-2007, 07:53 AM
DDY RCKT's Avatar
DDY RCKT DDY RCKT is offline
Originally Posted by Steve1968LS2
Bret is the owner of ART.. He's a stand up guy and he litterally beats the crap out of his cars.
I don't know what tires that was on.. could have been DOT R-compound tires.. but thier stuff has won enough auto-x events to have me convinced.
Cool, thanks! Just wanted to make sure. He should be out at PRI, then, right?
2002 Corvette Z06
Old 11-29-2007, 07:59 AM
DDY RCKT's Avatar
Steve, you're tech-ed at PHR!? That's sweet, man!
2002 Corvette Z06
Old 11-29-2007, 08:14 AM
Steve1968LS2's Avatar
Yep, but on here I'm just another knucklehead that spends way too much cash on this hobby. lol
I would imagine Bret would be at PRI. They are also sponsors on this board and will eventually see this thread and respond
Old 11-29-2007, 08:44 AM
The 1.2 number was achieved in the 66 Chevelle that placed 2nd at Run Through the Hills 3. Here is the track data link. And if you down load it you can follow it around the track
http://ridetech.com/streetchallenge/trackdata.asp
With every trick suspension set up available to us, we selected the Street Challenge set up for Project EmptyNest. Period.
Frank Serafine
Bret will be here for PRI, along with a half dozen other of the Air Ride crew.
Frank Serafine
Old 11-29-2007, 09:16 AM
DDY RCKT's Avatar
Well, true, but it's still cool.
If they do see this thread, maybe they'll walk on over to my thread and see what they think about beating the M3.
2002 Corvette Z06
Old 11-29-2007, 09:20 AM
DDY RCKT's Avatar
Fantastic! I look forward to meeting you and the Air Ride crew!
2002 Corvette Z06
Old 11-29-2007, 09:28 AM
Blown353 Blown353 is offline
Again, peak and average are two totally different things. This is why it's important to know how date is gathered and put together when a claim is made.
I know. I believe Keith's 1.17 was sustained, the logging was done on a Racepak G2X and at Brainerd. Hopefully he will see this and chime in.
Not knocking Bret's setups at all, they certainly do produce results. A good driver and well sorted out chassis helps a lot too.
1969 Chevelle
Old 11-29-2007, 11:46 AM
Lateral-g Moderator
I guess I'm an idiot, someone chime in and set me straight. With the car on air ride, when you lower the car it removes air that to me would seem to ride more sloshy and not handle as well as with more air and higher. Is it more the other suspension setup pieces that contributes to the handling numbers or is it the air.
