Old 11-01-2005, 10:38 PM
ohcbird's Avatar
ohcbird ohcbird is offline
I with Charlie on this one- start simple. Run it & warm it up to see if the readings go the same way as the electric gauge. Tap off right above the oil filter if you can get to it, if not there, then use the plug on the back (near the dist) of the block where late model senders usually are.
