Old 12-20-2007, 08:12 AM
TravisB TravisB is offline
Originally Posted by victionone
I don't plan to make 1000+ hp and the 454 LSX's aren't making any more power than a 427 LS7.
that depends on who builds the 454 LSx....
Kenny Davis Hot Rods
Old 12-20-2007, 09:43 AM
68protouring454's Avatar
I had to make the same decision and went with a LS7. The GM crate LS7 was a few thousand dollars cheaper btw. The LSX has a few extra cubes and is bulletproof. I don't plan to make 1000+ hp and the 454 LSX's aren't making any more power than a 427 LS7. The LS7 has a lighter rotating assembly, aluminum block, dry sump, and was cheaper.
are you serious? not making any more power??? on the edge of street driving, 11-1 lsx with a serious cam in it will see 700 hp easily n/a for 1/2 the price of a built ls7, and the ability to go bigger if something bad happens
Jake's Rod Shop
Old 12-20-2007, 06:17 PM
trapin's Avatar
trapin trapin is offline
My official "canned response" to this type of thread is; If money is not an option, go with what your heart tells you. If money IS an option, forego the "wants" in favor of the "needs".
To me I've always viewed the LSX block as something for the drag racing community. 2500 horse power? That's drag racing country. If you plan to have your face in the sky for the first 60 feet, then do the LSX engine. For a Pro-Touring car, weight is the big consideration, and for that I would do the LS7. Short on money? Then a warmed over LS3.
Tony Rapin
The Pigeon Forge Project
A 1968 Pro-Touring LS1 Camaro.........and why not?
Old 12-20-2007, 11:23 PM
rocketman's Avatar
There isn't that much wieght differnce in the two blocks, maybe 50 pounds
Old 12-21-2007, 04:47 AM
victionone victionone is offline
I apoligize. I meant to say not much more power than a LS7. The two 454 LSX dynos I have seen both dynoed under 600 rwhp. SW made 571rwhp on his LS7 with a cam. I know there are a lot of variables, and there is no doulbt a bigger cubed LSX will make more power. No arguement here.
I got a few estimates for a LSX build and they all ranged from $14-15k depending on components. This price includes injectors, rails, tb, coils, sensors, etc. Basically everything a crate GM LS7 would include. A GM crate LS7 can be had for under 12k and also includes a flywheel and clutch btw. A build with a LS7 block would cost $700 more since a LS7 block is about $700 more than a LSX block. I don't see how it can double the total cost.
Vic N
Old 12-21-2007, 06:02 AM
jeff s's Avatar
jeff s jeff s is offline
Supporting Vendor
It's actually well over 100 lbs heavier.
Thanks,
Jeff Schwartz
SchwartzPerformance
Where classic style meets modern technology.
Website : Facebook : Twitter
Old 12-22-2007, 09:28 PM
rocketman's Avatar
I didn't have a Ls1 block to weigh it doesn't seem that much heavier, but I found where it's a 105 pds heavier
Old 12-23-2007, 03:06 PM
James OLC's Avatar
for what it's worth:
http://www.ls1tech.com/forums/showth...37#post8356237
James
1967 Camaro RS - The OLC
1967 Camaro RS - Recycler
1969 Camaro - Dusty
Old 12-24-2007, 06:52 AM
tyoneal's Avatar
tyoneal tyoneal is offline
Originally Posted by reboot04
I guess for now, that takes care of that.
I hope they get things settled, for everyone wanting one.
TY
Old 12-24-2007, 09:49 AM
trapin's Avatar
I have a friend that builds engines, Chris Uratchko is his name. He owns Uratchko Racing Engines here in Michigan. We've talked about that block in the past and I remember him telling me his disdain for it. That was the first I heard that they were made in China. Interesting that this now comes out. I'll have to show him this thread.
Tony Rapin
