Old 08-05-2005, 09:39 PM
ProTouringNyC's Avatar
ProTouringNyC ProTouringNyC is offline
Default Rock Valley+69 Camaro= Gas Fumes
So nobody has a item number, part number for this specical secret gas cap amazing
Old 07-25-2006, 08:36 PM
69Lt4's Avatar
69Lt4 69Lt4 is offline
Anyone have the vented cap part number, Steve....
thanks,
Kevin
Old 07-26-2006, 07:22 AM
Payton King's Avatar
Default charcoal canister
Charcoal canister part number GM17056292. Spoke with Aeromotive about the gas smell problem and a guy that builds high end Willys street rods uses this canister.
Old 07-26-2006, 09:55 AM
rockdogz's Avatar
rockdogz rockdogz is offline
Default Update on this
I had a problem with the fumes initially, and actually built my own charcoal canister with activated charcoal from a pet store. It seemed to work ok, but I was worried about getting enough airflow through it to feed the tank. I had looped some fuel line around to attach to this canister, and once I removed the canister I didn't really sense the smell as much anymore. It seems that looping some 2' or so of fuel line off of the vent tube has cut down the amount of fumes enough for me, and then I don't have to worry about the canister.
-Tom
camarorestoration.com
Old 07-26-2006, 06:23 PM
69Lt4's Avatar
Payton - Any idea how big that canister is?
Kevin
Old 07-26-2006, 06:33 PM
rockdogz's Avatar
Kevin
Good question - some of those things are huge.
http://www.sdpc2000.com has it for $45.
-Tom
Old 07-26-2006, 09:15 PM
DRJDVM's '69's Avatar
I'd like to know too, since I have a Ricks Hot Rod tank but havent installed it yet. I'd like to get everything planned out before I do the install....
Old 07-26-2006, 11:12 PM
907rs's Avatar
907rs 907rs is offline
Kevin
Not sure about the size of the one that Payton supplied the part number for, but the one I plan on using is from a 90's full size blazer; it's about four inches in diameter by maybe ten inches tall - A hell of a lot smaller than the ones used in the eighties.
Bill
Old 07-27-2006, 09:04 AM
Default I have not seen one
What is the part number of the one from the blazer?
Old 07-27-2006, 03:55 PM
BRIAN BRIAN is offline
There is an easier solution. GM part# 10033125 is a small pressure valve that goes on the end of your vent line. Simply route the line outside and attach this small approx 1"x 2" valve. I run a orig 62 Rambler tank, in tank fuel pump and sump, stock cap as it is part of body, and this valve. When pressure builds that valve simply lets it out and then shuts again. A simple spring daiphram set up I believe.
Of course it has to be routed outside of the trunk area. Also if you have a trap door to access that tank make sure it is sealed with a gasket when it closes.
You should ask them exactly how they want that tank vented as you might collapse it if isn't braced but I am sure it is.
Good luck.
