Old 01-09-2008, 12:52 AM
deuce_454's Avatar
id like to see an article on any of the junkyard available engines, 5.3 ls1 or 6.0 that made big numbers on small money... there are so many allready written showcasing afr heads or brand-x cam...
also be sure to include the little secrets on how to modify OEM wiring, delete VATS+cat's and break down how the money is spent best..
Jake: Hit it.
Old 01-09-2008, 04:55 AM
Rick Dorion's Avatar
Rick Dorion Rick Dorion is offline
And include a reasonabley priced fuel system upgrade.
69 Camaro therapy program, 410, M22! SOLD
68 Camaro - SOLD
67 Bel Air - Hmmm.
Old 01-09-2008, 08:15 AM
JayR JayR is offline
Lateral-G Supporting Vendor
What about the very cheapest way to make 450-500 HP including the options you find while shopping and then follow someone like Tom Nelson or even Scott's TT in the Camaro through a big hp build including dyno results for both, maybe even get them in a car and test it in the real world and report on drivability, etc.
I like Chris (YouthPastor)'s ideas too but I think you can get one of these motors to make a 3000 pound car go 12s for half of $5000 or less and I think people would like to see how easy and cheap it can be done but then show the other side of the fence with an outer limits LSX.
People really need to know about the L92/L76 stuff and which motors it works on and what needs to go with it and what kind of hp numbers can be expected. Biggest bang for the buck I know of!
Can you tell how geeked up we are for this article?
Old 01-09-2008, 11:00 AM
Diognes56's Avatar
Diognes56 Diognes56 is offline
Originally Posted by JayR
I'm really surprised how many guys don't know about the L92 heads and L76 intake that you can get so cheap right over the counter. Not sure if you can put those on a truck motor but people should know about that stuff. Heads and intake for under a grand!!
If you could make a junkyard 5.3, 6.0 or 6.2 liter truck motor scream for low money, you would open a lot of eyes. The hardcore LS1Tech guys know all about L92/L76 upgrade but many people putting them in hot rods have no idea about it.
I'm also more interested in efi than carbs FWIW
Just so everybody is aware, the L92 heads will not fit on a stock 5.3L. They will only fit on blocks with a 4 inch bore and up (6.0L and up), the valves will not clear on the smaller bores.
David
Old 01-09-2008, 01:12 PM
David
Thanks David. Good to know!
Old 01-09-2008, 01:55 PM
pro-touring nova pro-touring nova is offline
do the 5.3 low dollor build up, or may be 4.8, i am doing a 4.8 in a 1979 nova
Old 01-09-2008, 02:36 PM
Jr's Avatar
Jr Jr is offline
Here is a quick list:
5.3 iron block bored out to take forged 5.7L goodies
6.0L heads
carb setup or ls6
blower cam
blower
Dyno test with 1 3/4 vs 1 7/8 headers
dyno test ls6 intake vs carb intake
Keep everything on a budget
Old 01-09-2008, 03:36 PM
radrambler's Avatar
Default truck engine
my opinion
#1 5.3 pull out from a truck base line it with the edebrock rpm setup.no mods
then throw a set of heads on it and cam.get the most you can out of the right grind of cam and tuning
#2 6.0 truck pullout base it with the edelbrock setup....then throw the book at it....no blowers ,just stuff that the average guy would buy and put on...im sure most would be shocked at the output....
i have found 5.3 engines for 250-300. and 6.0 for 7-900.....true low dollar start.
radrambler
Old 01-09-2008, 06:01 PM
Bad94 Bad94 is offline
How about taking a 4.8L and seeing what you can get out of it.
Above Average Motorsports
1972 Nova, Ride Tech, Forgelines, Wilwood, Bowler Transmission, Lingenfelter, RAFT.
Old 01-09-2008, 06:36 PM
skatinjay27's Avatar
im with ya jason!!! my friend just had a iron block 408 lsx built with l92s and that think is a beats!!! its in his 4th gen AUTO with a 4k stall and put down 484 rwhp and near 500 tq all motor...
AJ
