Old 03-24-2008, 03:49 PM
96z28ss's Avatar
96z28ss 96z28ss is offline
Why dont you take alook at the brackets on the Johns nova or brians. I saw the build up pics of your camaro and I bet a corvette system will clear. How much boost are you planning to run? Do you need to run the 8 rib system or a cog?
Rodger
Its a D1SC so I plan on running 10+ lbs but doesn't the corvette bracket use the factory serpentine system, then it would only be a 6 rib system that I could use. You'd have to change all the accessories to 8 rib or you'd have to move it out even more.
1969 Camaro LS2/T56 D1SC
www.automotivedesigneng.com
Old 03-24-2008, 05:24 PM
ironworks's Avatar
The 6 rib will not support 10 lbs of boost. Procharger sells all the pullies to make your system 8 rib. I really think the ZO6 kit would fit in your car. If I can fit it into a 5" ride height 63 nova both with tire and radiator clearance, I'm sure it should fit in yours. It was tight in brians but it can happen. What is your plan on intercoolers.
If you need some pricing let me know. Procharger will also sell and mock up unit so you can finish fab and then send back the housing and have all the guts put in. Just call me at the shop tommorrow.
Rodger
Old 03-24-2008, 05:56 PM
96z28ss's Avatar
Rodger
Show me pictures of your procharger with corvette brackets with 8 rib pulleys.
they don't list the 8rib on there website.
Old 03-24-2008, 06:18 PM
ironworks's Avatar
It looks no different than the unit on Brian or Johns. The spacers are just about a 1/4" longer to compensate for the 2 extra grooves.
Do you have any plans on the intercooler?
Rodger
Old 03-24-2008, 06:33 PM
96z28ss's Avatar
Rodger
I understand it only gets spaced out some more but what about the alternator, power steering, and water pump they all need the 8 rib pulleys also. The water pump isn't grooved but it probably should be wider also.
Do they make a kit for this??
Old 03-25-2008, 06:59 AM
ironworks's Avatar
Of course they sell the 8 rib stuff for the other. The water pump does not have to change.
Old 03-25-2008, 08:13 AM
Jr's Avatar
Jr Jr is offline
Instead of running a small pulley on the supercharger for more boost, you can buy a larger crank pulley from ECS. ECS makes them for the corvette system.
Jr's Avatar
Jr Jr is offline
Originally Posted by ProdigyCustoms View Post
We did the Prodigy Vette and uses factory Corvette stuff, but it will not fit in a Camaro.
What part of the corvette system would not work or fit on the camaro?
Old 03-25-2008, 09:26 PM
ironworks's Avatar
The power steering pulley might hit the upper control arm mount or the AC pump might hit the frame.
