Old 02-20-2008, 03:41 PM
6D9 6D9 is offline
Killer car...good luck with the sale
69 Camaro
491 BBC
TH400/GV OD
Currie 9"
Rushforth Livewires
Old 02-23-2008, 03:06 PM
Boatmaster Boatmaster is offline
TTT! Open to offers.
Old 02-25-2008, 09:57 PM
speedshopmike's Avatar
speedshopmike speedshopmike is offline
that's a fine looking car.
get some more, better, pictures up please.
Old 02-26-2008, 07:02 AM
I'll try and get some more pics up tonight. Thanks Drew
Old 02-26-2008, 07:25 AM
James OLC's Avatar
Cool car. So are you running the HP500EFI MEFI ECU with the 454 as is or has it been reprogrammed (or are you using a different ECU entirely)? When I had the HP500EFI in my ’67 I found the stock program to be a bit rich but tolerable. The ASM reflash helped a bunch.
James
1967 Camaro RS - The OLC
1967 Camaro RS - Recycler
1969 Camaro - Dusty
Old 02-26-2008, 08:22 PM
I am still running the MEFI 3 ECU with a custom map. Dustin Whipple from Whipple Superchargers has helped me with the mapping. It was mapped to my cam specs and compression ratio. The final map ended up being much leaner than the marine version. Also needed to up the rev limiter and overheat temps. The car comes with two ECUs also. End all result is this car is very turn key with unreal throttle responce.
Old 02-28-2008, 12:20 PM
This car needs to go. Open to offers!
Old 03-02-2008, 10:25 AM
Bump!
Old 03-02-2008, 11:42 AM
4mm 4mm is offline
Post or host more pics Your car looks very nice
Old 03-02-2008, 12:52 PM
dropit69 dropit69 is offline
sweet ride..i see you have 5 inch speedo and tach are the others 2 1/8 or 2 5/8 ? is that a custom dash panel or boughten one?..good luck with sale awesome ride !!
Darrin
1971 Camaro
1971 Camaro RS
1973 Camaro RS "Dreamsicle"
1969 Camaro Coupe
1969 Camaro Convert -Pro-Tour build
www.fquick.com/dropit69
