Old 06-17-2008, 07:39 PM
Psst! Blake! The moving of the upper control arm with the slots going down and rear ward adds caster in addition to camber.
The easy way to align the frame is with a digital angle finder on the cross shaft to make sure they are in the same angle during the alignment period.
Killer product by the way.
Tyler
Old 06-17-2008, 07:44 PM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
Originally Posted by killer69 View Post
The idea is that yes they are adjustable the upper end of the slot is the stock location and the lower end of the slot is the g mod location
Not a bad idea. You can use the stock position and something like the ATS tall spindles, or the G-Mod location and the stock spindles.
Old 06-17-2008, 09:54 PM
Blake Foster's Avatar
Correction, thanks tyler, i suppose what i ment was that it mostly affects the camber curve/change but yes it will add caster that could be shimmed out/or back to your chosen setting,
some have asked if the Gmod will work with a tall spindle also like the ATS unit and the answer is no, well not no just not necessary the tall spindle and the Gmod both accomplish the same thing in different ways, feel free to add to the discussion tyler
Blake Foster
www.speedtechperformance.com
Old 06-18-2008, 01:00 AM
deuce_454's Avatar
my comment about adjustable castor gain was thay one could in theory set the shaft at a different anglt than stock as the slots allow lifting the front bolt up. while leaving the rear down... this will give a different castorgain and antidive... and that will... be the proverbial biatch to dial in....
Jake: Hit it.
Old 06-18-2008, 08:44 AM
i theory yes... but there is not that much "slop" ( technical term) the shafts really only want to slide parallel in the slots. they might rock(for lack of a better word) 1 deg.
so it really is not something to be concerned about.
Blake Foster
Old 06-28-2008, 05:02 PM
scherp69's Avatar
scherp69 scherp69 is offline
Got the Speed Tech high clearance control arms that come with the Speed Tech subframe complete package. Here's a few pics the control arms and sway bars. More pics in my build thread. These things are awesome. Speed Tech say you can put a 10" rim with 7" backspace with this package.
Upper control arm
Lower control arm
Tie rod ends
1.25" solid sway bar
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
Old 05-23-2009, 12:17 AM
scherp69's Avatar
For anyone interested in the Speed Tech subframe...I thought I'd post pics of it powder coated and assembled. This thing is awesome.
Mike
New Gen Splitters
LS3 and TKO600
Old 05-23-2009, 02:46 AM
jcal87's Avatar
jcal87 jcal87 is offline
How much would i save going the speed tech route over DSE? What are the major differences as for a quality and options? I don't mean to hi jack the thread by any means it just seems that you guys have a lot of knowledge on these products. I assume y'all have done extensive research so i' m wondering if you could enlighten me on the 2 frames that i will be buying in the near future. I was leaning dse but after reading some more reviews I'm still considering Speed tech. I guess i just want the pros and cons affordability and function of both
sorry if its hard to understand blame ambien.
1968 Camaro Blue
1968 Camaro SS (Sold)
Texas A&M Alumni
Old 05-23-2009, 05:46 AM
The Speedtech frame is right at $2k less then a DSE.
Frank Serafine
Old 05-25-2009, 08:33 AM
Another interesting question on this. I know of someone that put a LS2 in his car on stock sub and used the mounts that dropped the engine to get his KB to fit under a stock height cowl. Does the speedtech frame lower the engine any? There is a possibility of running a blower on my car and I really want it to fit under a stock cowl hood.
Maybe not the right area to ask but we're discussing the speedtech frame so worth a shot!
William
p.s. That frame looks NICE!
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
