Old 08-16-2005, 07:59 AM
Mecom Racer's Avatar
Mecom Racer Mecom Racer is offline
Originally Posted by blazen
I’m still new at this but what is the difference between the stock wiring harness and the Speartech harness, just wonder, I’m still going to order the speartech because my motor didn’t come with a harness. Thanks for your commits, Alex
No difference. He can provide one for you and customize it to eliminate things you won't be needing or to lengthen certain leads, whatever...
The best thing about the LS1 harnesses is that every plug on it is unique. You can't plug something together wrong!
"Well, the trouble with our liberal friends is not that they are ignorant, but that they know so much that isn't so." -- Ronald Reagan
http://photobucket.com/albums/v494/M...ort%20Tribute/
Old 08-19-2005, 06:07 PM
Derek69SS's Avatar
Does the same advice apply for the LT1 harnesses?
Looks like $650 for either speartech or painless for a new one, or $450 for a reworked OEM harness at speartech. (cheap is good, easy to for an electronically challenged guy to figure out is better)
Thanks!
Old 08-21-2005, 10:40 PM
Thanks!
Yes, LT1 too. Go with Speartech.
Old 08-22-2005, 10:05 AM
Steve1968LS2's Avatar
Speartech...
Old 08-22-2005, 01:55 PM
Originally Posted by Lesrace82
Speartech reworks stock harnesses or he builds them from scratch too I believe. He can make leads as long as you need them to be so you can mount the PCM pretty much anywahere you want. Ive heard nothing but good things about his work.
You are right! John did my harness too and exactly perfect fit!! He allso gave me really good support via emails and by phone. I can highly recomend hes stuff!!
Old 08-22-2005, 03:29 PM
Derek69SS's Avatar
Thanks guys, you've just saved me $200 that I can spend on the rest of the swap
