Old 08-10-2008, 09:55 AM
1960LesPaul's Avatar
1960LesPaul 1960LesPaul is offline
Default Rushforths are here!!!
Got them on the car and they look great but really show now that the the car needs to be lowered bad. I was hoping to do CPP big 4 wheel disc brake set up but now I think I need to work on the suspension first.
My biggest problem is I am rubbing bad. My rear end isn't square so I thought I would have to massage the wheel lip on the drivers side but I am rubbing on the passenger side inside and out. This is the side that has me puzzled. Why is it rubbing on the outside when I now have more room then when the 9.5 TTII's were on it. I guess since this wheel and tire combo (295/40/20 is much taller then the old set up that it is putting the sidewall bulge right on the quarter lip and because I need to shore up the rear end wiggle it's touching because of too much side to side travel. Does this sound reasonable?
Since I need to do some work on the rear what to you think of the CPP rear end setup with all 4 trailing arms and sway bay with brand new bushings? And maybe some QA-1 shocks with lowering springs? In the mean time we are going to trim the lips some more. here is a link. It's the top one on left.
http://www.classicperform.com/NewPro...iling_Arms.htm
