Old 09-02-2008, 11:21 AM
AJSZR2326 AJSZR2326 is offline
okay i called, i didnt realize you lose your back seat with their chassis! i like my back seat. thats why i got rid of the vette(no back seat).
Old 09-04-2008, 09:21 AM
CraigMorrison's Avatar
CraigMorrison CraigMorrison is offline
Not necessarily true. On the First Gen Camaro we are doing a replacement rear sub that you can do either a tri 4-bar or a 3-link. The tri 4-bar stays completely under the stock sheetmetal and the three link comes through. Both can still keep the stock seat in the back. It all depends on how low you want the car to be. Super slammed, then yes you probably will have to get rid of the back seat.
If you are doing a true 4-link (pro street style and not a 4-bar or tri 4-bar) yes, you definitely have to eliminate the rear seat due to framerail and suspension design.
Art Morrison Ent.
www.artmorrison.com
Old 09-08-2008, 05:02 PM
Y-TRY Y-TRY is offline
Hey Craig-
When I first started looking at your Tri 4-bar, I was quoted an outside framerail measurement of 40". That would be a bit narrower than the stock rails and would require another fuel tank (if I remember correctly).
Have you designed a clip specifically for the Camaro since then, with different specs?
If these are two different set-ups (maybe Camaro vs. Universal), and I want the narrower one, will I lose the backseat? How much narrower can the Camaro clip be ordered while still retaining the back seat?
In short- I want a Tri 4-bar clip for a '68 Camaro, retaining the back seat, yet narrower than stock for more tire. I don't mind cutting into the trunk or floor as needed but still want the seat. Possible?
Old 09-08-2008, 05:45 PM
We do a Tri 4-bar rear subframe for these cars that fits under the stock floor, you keep your stock fuel tank and back seat and you can run a 335 tire.
Even with our 3-link rear sub you can still keep the back seat and fuel tank (but you do have to break through the floor and trim some seat springs)
Art Morrison Ent.
www.artmorrison.com
Old 09-08-2008, 06:14 PM
as Tim Taylor would say in this case... MORE TIRE!!!
I'm looking to run a 345. Yea, nay?
Old 09-08-2008, 07:11 PM
lhkustoms's Avatar
lhkustoms lhkustoms is offline
Originally Posted by tmadden View Post
Thinking about buying one this week. Any opinions or experience with it. Going on my mini tubbed 67 Camaro
I Think Art Morrison products are great high quality but I recommend using Chris Alston Chassisworks Tri-4 bar rear clip Extremely High quality and fast turn around time It shipped 2 days after I ordered. Just my opinion there is nothing wrong with the Morrison rear clip
Luke Mau
L & H Kustoms
Old 09-09-2008, 05:15 AM
I'll double check with Matt to see if 345's will work. How big of a front tire are you running? 285's or 295's?
Art Morrison Ent.
www.artmorrison.com
