Old 09-26-2008, 07:14 AM
GMracer's Avatar
GMracer GMracer is offline
Well haven't updated due to me forgetting the camera, but I've been working on mainly figuring out my front suspension I wanted to make it perfect at ride height, and finally after moving everything upwards, motor 1.5" up i got my arms at 2* LCA and the uppers at 6* this is set at 5.5" ride height. Tire will sit right at the lip of the front tires.
So with that figured out, I started the front crossmember
crazy cuts to make it fit
Made sure the tierods would be clear, at full turn they hit so I will make a small round notch
Nick Schiffer
2001 Silverado Regular Cab Short Bed
Currently Under the Knife
Special Thanks to:
Air Ride Technologies - Wilwood Engineering
Old 09-26-2008, 07:15 AM
GMracer's Avatar
Tac'd
At final position
Nick Schiffer
Special Thanks to:
GMracer's Avatar
Centered the rack up, took some measurements
Check out those arm angles, perfect!
Nick Schiffer
Special Thanks to:
Old 09-26-2008, 07:16 AM
GMracer's Avatar
Got the steering mocked up
Nick Schiffer
Special Thanks to:
GMracer's Avatar
and some more pictures...
Check out this, the body bout doesn't have much room to weld to so I could do a plate angle up on one side and the other going down, but I hate that look
so why not make it look factory
all done.... :crazy:
Nick Schiffer
Special Thanks to:
Old 09-26-2008, 07:17 AM
GMracer's Avatar
Cut some steel
Nick Schiffer
Special Thanks to:
Old 09-26-2008, 07:18 AM
GMracer's Avatar
Welded up and smoothed out, the 2" hole will be drilled later
Nick Schiffer
Special Thanks to:
GMracer's Avatar
had a few extra hands...
haha not, I wish though.
So I continued with that crossmember, made stock styled rack mounts.
Going to cut down some of the excess on the opposite side
Beveled edges and a nice solid bead
Nick Schiffer
Special Thanks to:
Old 09-26-2008, 07:19 AM
GMracer's Avatar
Back on the frame
Temporary bolts holding it in place
Lower control arm mounts, I was going to have them laser cut, but seemed like a waste of money and time for what I will need
Nick Schiffer
Special Thanks to:
Old 09-26-2008, 07:20 AM
GMracer's Avatar
started the second crossmember (under the oilpan)
this is going to mount the back of the LCA and then the motor mounts ontop, the middle of the crossmember will be bolted in similar to factory setup.
Nick Schiffer
Special Thanks to:
