Old 09-27-2008, 09:52 PM
blowngasr blowngasr is offline
bet that heart rate went WAY-UP..................are your shoes smokin from movin so fast.......... ...................................only makin fun cause everythings ok......................the wizzzzz
Old 09-27-2008, 09:55 PM
camcojb camcojb is online now
yeah, fortunately you don't have to bail me out on this one........................ I do have to buy a new pair of shoes, black melted plastic all over my favorite ones...........
Old 09-27-2008, 10:02 PM
makes me wonder what the old combo would have dynoed with decent mufflers...................
That is the otherside of the coin when builders hands are tight on sponsors products...
What a horror story with the fires .It could be much worse.
63 Z06
Old 09-27-2008, 10:14 PM
Flash68's Avatar
Flash68 Flash68 is offline
Good to hear Jody.
And good lesson on the fire ext. I know I am going to put one in - I didn't plan on it or even put any thought into it before.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 09-27-2008, 10:18 PM
Blown353 Blown353 is offline
Great news... the mufflers anyways. The small fires are another matter entirely.
I'm kicking myself in the ass now for not asking you about the mufflers earlier. I remember when we were standing under the car on your lift and I saw those Stainless Works mufflers I meant to ask if they were "turbo" style mufflers (S-path) or the straight through variety-- stainless works makes both!
http://www.stainlessworks.net/cart/i...423d9fe6e6ad54
Obviously you had the "turbo"-style with the S-bend flowpath. Yuck!
If you had stuck a pressure gauge in one of the WB02 taps that would have told the story immediately...
A 5psi drop across the intercooler is still working the turbos harder than they need to be but if you're happy with the power and the IAT is reasonable I'd live with it rather than having to redesign and refab the entire nose of the car.
Next question... I believe a certain Silver twin turbo 69 Camaro in our area also has a stainless works exhaust... he might want to verify what mufflers he has, although based on how the car runs I'm pretty sure he has the straight through style.
1969 Chevelle
Old 09-27-2008, 10:53 PM
gearheads78's Avatar
gearheads78 gearheads78 is offline
Glad to hear you got it figured out and very glad this post did not include pics of a crispy Chevelle on the side of the road.
-Richard
66 Cutlass "Joe-Touring"
54' Olds 88 "Joe-Touring 2.0"
69 SS Camaro 4-speed (wife's)
Richard J.
If only I had the time talent and money to build everything in my head
Old 09-28-2008, 07:02 AM
I wonder if I even have a 5 psi drop now. Since the wastegates are sprung for 19 psi and I had the manual boost controller up all the way, it should be making 24-25 psi. The way the boost flew past 20 psi (gauge only goes to 20 psi) it may not be as bad as I thought.
Yes, the owner of the silver Camaro may have the same mufflers, as his car is every bit as quiet as mine was. You can tell the sound difference between the two easily, even with turbos. He is aware of it, and will be checking them soon.
Old 09-28-2008, 01:16 PM
projectile's Avatar
projectile projectile is offline
Glad to hear that you solved your boost problem!
It sucks that it caught fire. Could've been worse! I see you lost a pair of shoes, did your shorts survive?
Ray
Old 09-28-2008, 02:19 PM
yeah, but it could have gone either way.............................. Damage is very minimal after looking some more today. Just the outside plastic piece of the fuse block that holds the fuses was damaged, all wires behind and on the firewall plug are perfect. Hopefully AAW can sell me just this piece.
I'm ordering a Safecraft extinguisher like Scott has tomorrow.
Old 09-28-2008, 06:35 PM
DRJDVM's '69's Avatar
Wow....glad to hear theres wasnt much damage..
Any idea on why the electrical fire ??
