Old 11-12-2008, 11:50 AM
brrymnvette brrymnvette is offline
I'm confused on the point of the sprockets? Are they welded together? Or is that how you secure the car at the angle you want? You bolt the one sprocket to the other, holding it in place.
Old 11-12-2008, 12:52 PM
scherp69's Avatar
scherp69 scherp69 is offline
Each sprocket is welded to one of the tubes. One sprocket to the 3" tube and one to the 2 1/2" tube. When the 2 1/2" tubes spins inside the 3" tube, the sprocket on the 2 1/2" tube also spins, but the one on the 3" tube does not. I then drilled 8 holes in the sprocket welded to the 2 1/2" tube. These holes are for different locations that the car can be set at. There are nuts welded in place behind all the holes on this sprocket. The holes in the sprocket that's welded to the 3" piece are to put the bolts through, into the nuts welded on the other sprocket to secure it in place.
That was the long answer..the short answer...no they are not welded together and yes they are to secure the car in place at the angle I want it.
Hopefully this made sense. I'm hoping to start undercoating the car next week and have it off the rotisserie a couple weeks after. Once that is done, I'll take some more pics of the set up.
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
Old 11-12-2008, 01:00 PM
That's exactly what I was asking, and exactly what I thought they did. Thanks.
