11-06-2008, 12:07 PM
The real issue with dead head systems is what's called 'hammering', or hydraulic shock. This occurs when the 'column' of fuel in the rail is subjected to the pressure changes induced by the injectors opening and closing. To combat this, fuel dampners can be used, but it's better in high-volume applications to use the typical return style system.
Look at the dampners at this sight, and the explination of hammering.
http://www.injector.com/fueldampers....72ee3053fe9e5a
Yes, it is much easier to package dead-head systems, and with smaller injectors and demand, it's usually not a problem.
1971 Lemans Sport 461 bottle fed daily driver
1971 Trans Am 474 blown EFI pro tour car
1972 442 W-30 clone
11-06-2008, 04:30 PM
would "hammering" be as much of an issue on a car with sequential EFI, compared to a car with a bank 2 bank set up, where all the injectors fire on one side simultaneously?
11-07-2008, 06:42 PM
never had that issue, and I've always used it (dead head) with 75 or 95# injectors. The fuel pressure never wiggles at all, sender is in the rail. If I have an issue that's a cool thing to try, but no reason for it as far as I've experienced.
11-09-2008, 06:54 PM
Jody, what kind of pumps & regulators do you run? Do the pumps you run use an internal bypass of any kind? Curious. I've always understood that with dead heads pumps don't last as long due to heat, and fuel pressure at WOT isn't stable. I've also understood that fluctuations of 4-5 lbs at WOT is in fact due to hammering, and to steer away from dead head systems. I personally have only used bypass styles to avoid these kinds of issues, and have never done a dead head, because of my understanding, but maybe I need to rethink my ways?
1972 442 W-30 clone
11-09-2008, 07:21 PM
my systems still bypass, just that the bypass regulator is located at the rear of the car instead of the front. I've used Aeromotive, WalBro, Bosch, and many other pumps, but currently have an Aeromotive pump and regulator. I do not see any pressure fluctuations.
11-10-2008, 04:42 AM
JMAC - Yes, in theory, bank 2 bank is more susceptable to hammering than SEFI.
Jody- You've certainly drawn my curiosity here. I was also under the impression that you want the regulator as close to the injectors as possible, which allows for a faster reaction time to pressure variances. I understand (and have seen others with) your setup, with the regulator in the rear, though it goes against all the design theory I've been taught or researched, so I'm trying to understand. You're saying you see no variations in pressure? Is it possible you're just not seeing it? What types of rail pressures do you use? Generally higher pressures, like 60+?
I've seen 'recommended' system maps by manufacturers of pumps, and as I recall, all recommend the typical bypass system with the regulator either on the fuel rail or right at the fuel rails. I have lately also seen several aftermarket projects that use dead head systems, which has made me wonder.
I'm getting ready to help a friend with a fuel system project that is a big block supercharged application. Space is a premium, and if possible, a dead head in this case would be an answer to the packaging. Maybe I need to go back and re-research the topic, since it seems my knowledge may be dated.
1972 442 W-30 clone
11-10-2008, 07:31 AM
I am currently running 52 psi and have added a boost reference line to the regulator for 65+ psi under boost. But I have also run the rear regulator at much lower pressures.
Regulator on the rails is the normal way to do it, may even be the best way although it hasn't been proven out with me. One thing it does cause is very hot fuel is being bypassed to the tank. I and many others have had issues with the hot fuel heating the tank enough to cause fuel pressure issues and shutting off the pump. Won't likely be an issue with short trips in town, but on longer runs on a freeway (like Power Tour) or during track use it becomes a big issue.
You could add fuel coolers to the return line I guess, but that's just more junk to bolt on the car. I moved the regulator to the rear of the car years ago after I saw GM doing it on the Vettes (got the idea from a local EFI tuner). Never had a fuel heating issue since, and with my fuel pressure sender in the rails see no variance in pressure at all, no vibrating needle, nothing. That does not mean it isn't happening, just that I can't see it on the gauge or in a/f logging, and the car runs fine this way. I was told the dampner was used as much for noise and resonance as anything, which is an issue in a brand new super quiet insulated car with a warranty, not so much in an older hot rod like we build. I sure haven't heard anything.
11-10-2008, 08:00 AM
Hot fuel shutting off the pump & pressure, like from the pump failing from the heat?
I did the Power Tour with a bypass setup (Gen6/Aeromotive), and drove 3300+ miles in 7 days, some days 9 hours or more straight, only stopping to gas & eat. I never suffered a fuel heating issue (pressure rise/drop), or pump failure, and this was 80-90+ degree weather, bumper to bumper stop & go at times. Maybe I just got lucky? The only area that would in my setup absorb heat would be the rails themselves, every other area was either away from radiant heat or wrapped.
New vettes are dead head? I've never noticed, or looked for that matter!
Hm, maybe I'll take a shot at dead heading my friend's project. Would give him ammo though if he had problems with it! Sure would make life easier though, that's for sure! Thanks a ton for your input, greatly appreciate it!
Oh, how did you run the boost reference line back to the regulator?
1972 442 W-30 clone
11-10-2008, 08:14 AM
2005 Power Tour there were at least 6-8 guys that I personally saw stranded like us with the fuel heating issues. I was in a borrowed car that I didn't plumb, we ended up adding 20' of coiled copper tubing in an ice chest to the return line to make it through the tour.
Vettes, GTO's, and others have been regulated at the rear for many years now.
01-26-2009, 05:42 PM
Many of you may remember my car and its fuel problems at Pigeon Forge. I actually over-nighted a new A1000 to Bill's house/shop and replaced the pump in an attempt to fix it. My car was doing the 30 minute boogie -- and it just started that weekend. During the actual run through the hills, I had to stop every 10 minutes or so to let the fuel pump cool down.
'll know in a day or two, but it looks like my problem was dirt simple: I had a dirty fuel filter. (sorry...)
I've just now gotten my car back together after that (it now has an integrated iPhone/stereo and A/C). I also re-plumbed the fuel system to route it away from my headers, and added an Aeromotive fuel pump controller (shout out to Steve Rupp: he's the man), and put in an RPS Street Twin clutch.
I've been doing a lot of shakedown runs (adjust the clutch, fix the alternator whine in the stereo, see if the defroster works, etc.).
Wouldn't you know it, my car crapped out just like it did in Pigeon Forge. This time I measured the temperature of the gas in the tank (easy since I just filled it up). 78 degrees.
The fuel rail temperature was 108.
A re-read of Aeromotive's website (I run all their stuff: A1000, fuel filters, regulator, fuel rails), and I happened on a little gem that said a restrictive fuel filter on the suction side can cause cavitation of the fuel pump. So I pulled my filters out and examined them. The suction side filter was fine: no noticeable debris. But the pressure side was black with chunks of my old Russell SS hose in it! Why I didn't check that at Pigeon Forge is beyond me. I checked the suction side, but not the pressure side.
I think the pressure side filter had enough restriction that the fuel pump was working too hard to push fuel through it... over time (say.. about 30 minutes) it would overheat and cavitate.
I've heard reports of the 10 micron filter needing to be replaced often. Anybody else heard of that?
Anyway, a new element is on its way. Sometimes the little stuff matters.
jp
