Old 10-18-2008, 11:41 AM
camaro2nv's Avatar
camaro2nv camaro2nv is offline
Originally Posted by rich-allen View Post
I forgot to mention that I'm running my stock subframe as well.
I didn't go with Air Ride but I did replace everything else with aftermarket.
So Frank is right, you don't need an aftermarket SF however, the ATS subframe kits are smoking bad ass!~
I hear ya! Just that look is killing it! I want SUPER clean!
Old 10-18-2008, 11:45 AM
camaro2nv's Avatar
I just got a call on my stock subframe. I listed it for 1000.00 complete. Maybe I will just sell it.
Being that I run a wheel/ after market shop I should be able to get hooked up on some stuff.
Man I need to finish my bathroom remodel so I can down on this car. Right now every time I touch the car the wife gives me a sideways look Man the deals me make
Old 10-18-2008, 11:49 AM
rich-allen's Avatar
rich-allen rich-allen is offline
You run an aftermarket wheel shop?
Cool.
DSE subframes are nice and expensive but very nice, art morrison is swqeet too. The ATS kit was used on the One Lap Camaro build, very sweet indeed.
You should be able to find a SF from the sponsors on the left too.
Rich
67 RS/SS
Old 10-18-2008, 11:55 AM
camaro2nv's Avatar
Check out www.ilovewheels.com By posting the link I dont want to get in any trouble so if its not allowed mods please remove it.
If I can get 1k for the stock subframe I think I just might take it.
Old 10-18-2008, 12:19 PM
camaro2nv's Avatar
Wow this is nice!
http://www.jimmeyerracing.com/cm1.html
Old 10-18-2008, 02:40 PM
If you sell your subframe and do a aftermarket subframe, I would run a Speedtech subframe with the Air Ride option. We can do it for under $6k to the door, and you get everything you want and more. As for the DSE frame, it WILL NOT run Air Ride, so it is out. morrison is very nice , we sell it to, you will spend another grand on it.
For the rear, Our upgrade G bar (Prodigy Bar) is pretty nice and easy to install. but we sell the Quadra Link also, so at the end of the day i do not care which you buy from us.
Here is some Prodigy bar info
https://lateral-g.net/forums/showthread.php4?t=16153
Here is some Total Car G machine brake Package info
Prodigy Customs introduces our Total Car G-Machine Brake Packages for Camaro, Chevelle, Nova, F body, A body, G Body, Ford, Mustang, Mopar and many others featuring the worlds best brakes, Wilwood Disc Brakes! Prodigy Customs EXCLUSIVE Total Car G Machine Brake Packages takes all the guess work out of your 4 wheel disc brake conversion. Our kits include front and rear Wilwood brakes in the size of your choice, front sizes from 10.75" - 14" rotors for all popular applications, Rear brakes include INTERNAL E BRAKE in sizes from 12.2" to 14" for all popular applications. Calipers are available in Four Piston to Six Piston, Dynalite and Superlite Calipers Our exclusive Total Car G-Machine brake packages include everything required to convert you original brakes to monster 4 wheel disc. Call for your exact application.
Kits include:
Wilwood Parts Include:
Front and Rear Wilwood Kits
New front Hubs
3 pints Wilwood DOT 4 high temp Brake Fluid
Prodigy Customs Parts Include:
Front Braided Brake Hoses
Rear Braided Brake Hose
E brake Cables for Internal E Brakes
Master Cylinder
Adjustable Proportioning Valve
We even include Safety Wire and Safety Wire Pliers for proper 2 piece rotor assembly
10.75 to 12.2"F / 12.2" R kit is $1850
NOTE:
($1850 Kit includes BLACK CALIPERS and NON Drilled / Slotted Rotors)
Upgrade cost are ac***ulative and are added to base kit price of $1850
Upgrades include:
(6) piston Dynapro front caliper upgrade (12.2" kits only) $400 option
13" (6) piston Superlite front upgrade $900
14" (6) piston Superlite front upgrade $1100
13" (4) piston Superlite rear upgrade $900
14" (4) piston Superlite rear upgrade $1100
Drilled and Slotted Rotors are $200 Option
Red, Blue, Yellow, Silver and Polished Calipers is $200 Option,
Wilwood Aluminum Dual Reservoir Master Cylinder is $170 Option
Wilwood Aluminum Dual Reservoir Master Cylinder (polished) is $200 Option
Dual Diaphram Polished Stainless Power Brake Booster $200
Hydratech hydro booster (Deluxe kit with lines) $650 option
Base Total Car G Machine Brake Package with 12.2" F (4) piston Dynalite / 12.2" R (4) piston Dynalite kit as shown with Upgrade:
RED CALIPERS,
DRILLED AND SLOTTED ROTORS,
POWER BOOSTER
AS SHOWN IS $2450.
Extreme Total Car G Machine Brake Package with 14" F (6) piston Superlite / 14" R (4) piston Superlite kit as shown with Upgrade:
BLUE CALIPERS,
POLISHED WILWOOD MASTER
AS SHOWN IS $4650.
Custom pedal set NOT INCLUDED
Frank Serafine
Old 10-18-2008, 02:46 PM
Originally Posted by camaro2nv View Post
Bling, Bling, Bling,..............................Street Rod stuff.
There is a few other out there in this catagory.
We have better stuff for less money.
I run this one in Project EmptyNest and am super happy with it, with Air Ride.
http://www.speedtech-performance.com...cat/cat214.htm
Frank Serafine
Old 10-18-2008, 05:30 PM
camaro2nv's Avatar
Very nice stuff! Frank right now Im just gathering pricing. I have a lot of work to do before I order many parts. Im starting with the body, tubs, firewall and going from there.
Prices for this stuff seems to vary a lot. I like that Prodigy bar with the 12bolt. What does it run with the 12bolt and shockwaves? I do apprichate you posting this stuff and will keep it in mind when I do order. Maybe once Im ready you can give me a package price.
Old 10-18-2008, 05:55 PM
Depending on the horsepower (rearend requirments), single or double adjustable shockwaves, your right at $4500 to $5000 for everything.
Frank Serafine
Old 10-18-2008, 06:05 PM
camaro2nv's Avatar
I think Im going to have to add to the budget,lol. Those Brakes are lookin SWEET!
