Ugh, that sucks. And I agree 100%-- given the current economic times and unemployment rates this sort of thing will only happen more often.
Originally Posted by syborg tt
Safe's are not a good investment unless your trying to keep your wife and kids away from your guns or money.
My fathers neighbor was robbed about 2 years ago and they used a metal detector to locate all of the hidden safes in the house. They also found the bigger safe in his home and flipped it on it's back and opened it. Obviously they new what they were doing because then were able to get into all 3 of his safes.
There is a big difference between what most people call a "safe" which is actually just an RSC (residential security container, a glorified sheetmetal box) and a TL-rated burglary resistant & rated safe.
99% of the people out there buy a "safe" (usually rated RSC or not rated at all) and expect it to be their end all, be all security solution-- that simply isn't the case. If they're spending under $4000 or so it's probably not going to be a "safe" and rather a RSC-rated storage container and they also probably have false exaggerated hopes of their newly acquired security.
Flipping an RSC onto the back makes it much easier to pry the doorframe open or beat on the corners with a sledgehammer to pop the welds-- I take it from your description that it wasn't properly anchored to the floor.
Safes buy you time-- that's all. The more you spend, the more time you get before it can be opened. Given enough time and tools you can get into anything. Buying a more expensive TL-rated safe just means more layers of security, thicker metal, a locking mechanism that can't be easily pushed open, etc, and it's harder to get into and will take more time. The more expensive TL-rated safes are quite effective at resisting "smash and grab" type of burglaries but against a experienced pro who has lots of time (or a guy who doesn't care about the contents and uses a torch or lance, in which case your contents will likely be ruined by the time he gets in) your stuff will still be gone.
