Old 11-28-2008, 12:44 PM
Marcus SC&C's Avatar
Marcus SC&C Marcus SC&C is offline
We can help you with both the geometry and fittment issues. Either the AFX tall spindles or the stock spindles with the SC&C X-tall upper ball joints (which may be the ones you have?) and our bumpsteer correction tall tie rod ends will take care of the major suspension and steering geometry issues. A arms don`t alter bumpsteer no matter what anyone says. You can get some small improvement in bumpsteer by adding + caster but it`s not even close to half if you actually measure it with a bumpsteer gauge. The AFX spindles will will naturally provide a larger improvement in both suspension and steering geometry than we can get out of the stock spindles and offer much bigger wheel bearings etc. as well. Good comment above about brake caliper clearance. If you need an inch of clearance,add 1" of backspacing and a 1" bolt on adapter (the type with it`s own studs). For serious use it should be hub centric on both sides not universal fit. You can get them custom made for reasonable prices at wheeladapter.com Then you`ll have the wheels you want and lots of caliper clearance.
The Penske shocks and ATS brackets are a great choice.
IMO skip the R&P. Any percieved extra precision in the rack is lost in all the extra u joints in the steering shaft and any weight saved by the lighter rack is offset by the steel brackets etc. required to mount it. A Lee 670 box is 6.5lbs lighter than the stock 800 box and will give you more feel and precision than you`ll get out of most modern performance cars. Certainly better than our C5.
It`s nice to cover stuff on here because other folks can benefit from it but it`s also a little like talking with Post-it notes. Feel free to give us a call for more information. Mark SC&C
