Old 04-02-2012, 12:13 PM
Rhino Rhino is offline
The decision to run 1/2 height bushings really comes down to how much that .75 to 1" is worth to you. For me the additional effort isn't worth the relatively small (in my opinion) benefit.
There are plenty 1st Gens using full height bushings that don't have to touch the tunnel with a T56. It's a little tight, but has enough clearance to not worry about.
Old 04-03-2012, 01:02 PM
frojoe's Avatar
frojoe frojoe is offline
No bushings
Joe
1972 Nova with twin 6466's and T56 Magnum in the works. Speedtech, Ridetech, Wilwoods etc. Swap thread --> http://ls1tech.com/forums/showthread.php?t=980909
Old 04-03-2012, 04:49 PM
randy randy is offline
besides tunnel clearance what other issues are there when running 1/2 body bushings?
Old 04-03-2012, 06:32 PM
Ron in SoCal's Avatar
Possibly inner fender clearance depending on how low you go, tire size and how much suspension travel you have...
Ron in SoCal
69 Camaro in progress
Old 04-03-2012, 08:25 PM
what about the way the fender lines up with the door? I will be moding the inner fenders for max clearance anyway so that doesnt matter. I didnt buy the DSE front subframe and rear quadralink for the car to sit high. I want it low and to perform to the max
Old 04-03-2012, 09:08 PM
Rick D's Avatar
Rick D Rick D is offline
Randy, fenders bolt to the body not the sub frame so they will line find with the doors.
Rick
Old 04-03-2012, 10:42 PM
^ Listen to this guy. He's done it once or twice...
The bushings also mount to the core support and that supports the fenders, but the manufacturers have that height measurement down so as Rick said you'll be OK.
Edit: Unless you're going for the slammed look, the DSE sub and Qlink will get you nice and low.
Ron in SoCal
