Old 01-23-2009, 04:45 PM
James OLC's Avatar
I hear ya...I know how that goes. You call in twice and get two different answers. If you can verify enough disengagment it has to be internal tranny. Can you put the bellhousing back on and simulate the tranny with a bracket and measure the clutch disengament? Did it every creep in gear with the clutch in?
Right now the order of the day appears to be patience (at least for the weekend) and talk to Rockland on Monday to get there thoughts.
I was just on the phone with a very well versed friend/racer and his comments came around to fluid as well. He had asked if there I noticed anything with the fluid - which in fact I had - the fluid in the reservoir was slightly cloudier than the fluid in the brake reservoirs. He came to two possible reasons (naturally) - heat and water.
Going to go crazy sooner rather than later...
James
1967 Camaro RS - The OLC
1967 Camaro RS - Recycler
1969 Camaro - Dusty
Old 01-23-2009, 05:48 PM
68protouring454's Avatar
not that it pertains, but i have a spec stage 5 clutch in my 69, and it needed a .110 shim to give correct throw etc. that said i have the mcloed master, stock gm internal tb, and mine line is very close tot he header as well but i have it double wrapped in heat sleeve.
does it upshift fine in all conditions?
i would agree if it up shifts good(and has same tb throw everytime), it should down shift, unless there is an internal tranny issue(syncro etc)
Jake's Rod Shop
Old 01-23-2009, 06:31 PM
tjbruning tjbruning is offline
Not sure if this will help, but Centerforce recommended that we use a tilton 400 series release bearing. The stroke was changed using a different Tilton face bearing to get the stroke correct for our application.
Good tech in the Tilton instruction manual
http://www.tiltonracing.com/content....t2&id=209&m=d#
Old 01-23-2009, 08:56 PM
The WidowMaker's Avatar
when i talked to mcleod, they were big on getting the proper engagement though the use of shims. since they sell three different thickness' of flywheels, it just complicates things even more.
+1 on the shifting. i dont see how the tob cares whether youre upshifting or downshifting. all it does is release the clutch???????????
"The WidowMaker"
Old 01-23-2009, 09:38 PM
James OLC's Avatar
I wish that I had actually received some help from McLeod but no such luck... the guy didn't want to listen to anything after "I have a problem"... darn
I know what you are saying about upshifting vs downshifting - at least in principal - but I need to explore all of the options...
James
1969 Camaro - Dusty
Old 01-23-2009, 10:15 PM
JamesJ JamesJ is offline
Some good info here...
http://www.pro-touring.com/forum/sho...t=40904&page=3
James J.
Old 01-23-2009, 10:27 PM
Great info James!
Old 01-23-2009, 10:32 PM
The trans has ATF fluid in it? If you put 30W it will have problems shifting. I have to disagree about upshifting and downshifting, upshifting is easer to do with out the RPM "matched" Drive around and shift with out the clutch and see ow it acts. Maybe you will learn somthigng else that can lead you to the answer.
James J.
Old 01-23-2009, 10:45 PM
when the car is sitting can you tell any difference in upshifting or downshifting? And then when the car is running is it the same? When you engage the clutch all the way can you hear any audible differences?
James J.
Old 01-24-2009, 09:42 AM
fabricatordave fabricatordave is offline
http://www.thedrivenman.com/
call this guy he will talk to you he will answer call back 7 days a week usually
