02-21-2009, 09:37 AM
VERY NICE BUILD!!!!
Very detailed pictures. I love the rendering. Your car should come out AWESOME!
Keep us posted.
02-21-2009, 09:57 AM
The inner wheel houses are supposed to cant inward a little. Can't say they look right from just a pic. My guy that did minitubs on my 67' pointed out to me that he made sure they were "still tilted in like stock"
Pro body guys will use alot of X braces & support rods to stabilize the body while its all chopped up. I hope you have been doing all that to keep it measuring square. I very much admire your bravery to take on such a task!
My car got NOS quarters & tail panel & I was not up to try it.
Peter
02-21-2009, 10:49 AM
This build thread is well over due! Looks great Chris!!
Tony
'68 Camaro
02-21-2009, 02:24 PM
Nice work, I really like your rendering
Mike a
02-21-2009, 04:28 PM
Great job on tackling this yourself !! You'll learn alot doing it. Have you called DSE about the wheel tubs? They should have some insight as to how the fit is. Otherwise, keep up the Good Work and post more pics as you can.
Paul
1973 Z28 Street-touring project.........
02-21-2009, 04:36 PM
Peter
I used X-bracing over the back seat area and welded bracing from my rockers to my body cart. I was really nervous about the floor removal, but I measured everything good before I cut it out, and again after it was fully removed and nothing moved. I also welded bracing at the front of the rear frame rails and attached them to the cart along with bracing at the rear of the frame rails. We'll see when she's all put back together, but as of now, it looks good.
02-21-2009, 04:40 PM
Paul
I did call DSE and they said it looked okay and to weld it, but I knew it wasn't right, so I didn't.
I actually found my problem today. The front closeout panel (where the shock tower was) was too far in. I removed it and trimmed about 3/16" back and rewelded it. She's dead on now!
02-21-2009, 05:00 PM
02-21-2009, 05:05 PM
02-21-2009, 11:13 PM
It looks good it cleaned up nice and went in well.
