Old 07-17-2009, 10:55 AM
Originally Posted by Kokamo View Post
The fuse block is the best way to go on this, but to make it easier, you can splice off of the dist or coil wire. They are one sure wire thats hot with the ign on.
As for the throttle cable, I think Mr.Gasket makes an adjustable cable bracket.....might want to look into that. Summit may have something for ya.
~Joe
I would 'politely' disagree with stealing/sharing power from a coil or distributor wire....
Find a MUCH better place to take that 12V + from... the coil is not the place. It should also be from a 12V SWITCHED source....
Old 07-18-2009, 08:46 AM
av8or32 av8or32 is offline
I'll be re-wiring the whole car next month so It'll be right garanteed.
