Old 06-16-2009, 07:04 PM
av8or32 av8or32 is offline
Default Time to re-wire my car
I'm really dreading this. Mostly because I've never tried it. I'm wondering what the main differences are between the kits. For instance, when someone says that an AAW kit terminates it's wires, what does that really mean? Do they just add terminal ends or is there something else like specialized ends that'll cost me extra to add to a cheaper EZ kit? And if they just add terminals (like spade connectors) why are they so much more than say an EZ kit? In the end, will it cost me just as much or more to go w/an EZ kit @ $185 vs. a $500 AAW or Painless due to missing parts? How "universal" are these Painless universal kits. Are they so much so that they don't fit anything well? I have a factory manual with all the wiring diagrams since I know that's the place to start. I'm keeping my car as simple as possible since it's my first build. I won't be aading power window/locks etc. but I will be adding a/c and a sat radio set-up. So, how many circuits will I really need? Thanks for being patient w/a newbe.
Old 06-16-2009, 07:12 PM
youthpastor's Avatar
I've ran AAW - the owner Michael is a gearhead who loves G-machines. his products are worth the money and so is your time- every wire is labeled and he builds in provisions for everything. Don't skimp on wiring- hanging your head under a dash sucks bad enough- hanging it under trying to get stuff to work is just frustrating- good luck - keep us posted!!
Old 06-16-2009, 07:34 PM
Cread01 Cread01 is offline
Have you looked into the ISIS kit? that's the way I am going to go. it's more expensive but very cool.
Old 06-16-2009, 08:18 PM
I haven't , but I will
Old 06-18-2009, 01:06 AM
swollen swollen is offline
Terminated wires should mean just that, rather than the end being just wire, it comes with a terminal (hopefully the correct one to just plug in) pre-attached. Wiring isn't that hard as long as you have the right tools for the job. A test light, multimeter, ratcheting strippers, soldering iron, and patience is all you really need. It will be very helpful to have that factory wiring diagram, but also try not to remove all the factory wiring. Just take it one at a time. One final piece of advice I can give is get the best kit you are comfortable with. You don't want to change your mind on power locks down the line and have to add in unsightly wiring, its much easier to get a kit that exceeds your needs and just cap whatever you don't use for later.
Just one last thought, you may want to buy a bunch of loom to cover the wires to make them appear, or rather dis-appear a little easier. I prefer cloth loom over the cheap plastic split loom, but cloth is also more difficult to install. Oh, and disconnect the battery before you go messing around with the wiring. Good Luck!
Old 06-18-2009, 05:26 AM
JamesJ JamesJ is offline
The terminated ends have the factory connectors on the ends that are the correct length. I will be installing an AAW kit in just a few weeks, I will be using all the original dash gauges, counsel gauges, tail lights, marker signals, etc., so this kits works great for me. If you are installing all aftermarket stuff then it may not be the best choice for you.
The ISIS kit is something to look at, has many neat features and can be used in about everything, but to me its not that much cooler and does not make anyting work better. And like I said before you have to cut the wires and install terminals, not that hard but still takes a long time and is just about boring.
James J.
