Originally Posted by jhiphopjunky
I JUST PURCHASED THAT RADIATOR ON EBAY. ALTHOUGH I HAVE NOT RAN IT YET IT LOOKS LIKE A QUALITY PIECE! PERFECT FOR AN LS2 SWAP (I.E. HOSE OUTLET ON THE CORRECT SIDE) THE FIT IS PERFECT PLUS THE FANS AND BUILT IN TRANS COOLER AT $400 LESS THAN OTHER NAME BRAND SETUPS IS A GOOD OPTION! GOOD JOB ON THE RESEARCH
I actually purchased this radiator from Entropy with their wiring kit for the fans about 3 years ago for my LS1 swap - it fell RIGHT in, looks great, the fans are INCREDIBLY STRONG, and all the wiring looks perfect with thick 4 ga. wire(I think it is 4). It has worked perfect with my Camaro, and over the last 500-600 miles, it has never gotten over 195 with up to 95-degree temps outside, and it's got a 160-degree thermostat in it.
Only bads I can see - it stains easily and you have to set up an overlow/catch-can setup for it. I would definetly recommend his wiring kit for it, too - it is sealed up very well, has very long starting lengths, has a nice little fuse box/relay set-up...it makes it a breeze.
Or you could just get Frank's, and probably spend about the same? I paid right at $850 for mine, including all shipping. Plus you support a vendor...
