Originally Posted by race-rodz
i usually get it from a craft store...comes in "bricks" about 6x3x12", they also have a spray contact adheisive... that you can glue the bricks together with to get one big chunk... make sure to stuff some wood dowels in to help hold it together... as the glue works...but with the constant flexing from sculpting... the dowels do a better job untill you get a coat of filler over it to hold it all together.
btw........ when you start "sculpting" your gonna make a HUGE mess of green fuzz/foam chunks.... so make sure the shop vac is handy...especially if your doin it "in" the car
Thanks for the info, i just bought some floral foam and glued them together and used some wood "spikes" to hold them as the glue dries. I never realized how F'n expensive floral foam is!! YIKES!
I used to use a very similar material for molding rock climbing holds. i used to design them for a company in the twin cities as a side job. The only difference was this stuff was much easier to shape, you could literally use your index finger to polish it to what felt like 800 grit sand paper.
wish i knew where to get that stuff!!
