Old 10-08-2009, 07:24 PM
Thomo5150 Thomo5150 is offline
Thanks guy for you help and comments.
Hi Jim, that is exactly what I am looking for, thanks for your help. Love the 356 my favorite Porsche.
Hi Rhino, Excellent points made about weight and steering issues. I have planned to have the engine recessed into the firewall more than 10 inches. The engine will basiaclly be mid mounted. The Holden in standard form weighs the same as the C5 Corvette, I expect to loose about 200lbs from the swap. I have my racecar engineer designing the frame modifications for the chassis. I have a LMP2 type race car 1100lbs / 500+ hp Carbon fibre, Honeycomb alloy chassis.
The guy who lives next door built this in his garage so I can use is knowledge to find out how to go fast!!!!!
www.aussieinvader.com
Old 10-10-2009, 08:45 AM
Rhino Rhino is offline
It sounds like you have a well thought out plan. I can't wait to see some more progress.
How much interior room does it leave you with a 10" setback?
Old 10-10-2009, 09:28 AM
Still have room, comes half way under the dash, a taller tunnel is needed for the torque tube. A Kenne Bell supercharger is going on the LS6.
The LS engine sits about 3 inches from the firewall in the normal location, so the recess will be only 6 to 7 inches.
Old 10-12-2009, 10:24 AM
Front cradle is :
33 3/4 inches between C/L of the front mount bolts
34 inches between C/L of the rear mount bolts
20 inches between C/L of the front mount bolts to the rear mount bolts
Rear cradle is :
29 13/16 inches between C/L of the front mount bolts
28 1/4 inches between C/L of the rear mount bolts
17 inches between C/L of the front mount bolts to the rear mount bolts
My Project: 65 Porsche 356G
https://lateral-g.net/forums/showthread.php4?t=5109
Old 10-12-2009, 03:16 PM
Thanks Jim thats exactly what I need. will post more on this project when my parts arrive. Right now its back to sheet metal work and body prep for paint.
cheers Tim
