Old 10-20-2009, 03:36 PM
no they are too aggressive..
for a stock 69 your best bet is a 5 inch rear and an 4.5 in front..
7 inches of backspacing is too high..
Old 10-20-2009, 06:07 PM
dhutton dhutton is offline
Originally Posted by rogue View Post
What year Camaro. Will those rears fit a 69 without minitubbing? Very interested.
I have 18x10 with a 6" backspace on the rear of my 69 Firebird and it is a tight fit.
I think you could only use those 9" fronts with an aftermarket subframe.
Don
Old 10-20-2009, 06:12 PM
Thatcher Thatcher is offline
Thanks Amir and Don for your input.
Keep in mind, I can change the 10" rears back to 9's if necessary, but doing narrower outer lips or narrower inner barrels. Not sure if that would make a difference on helping with fitment on that guy's car or not.
Thatcher
Recaro USA - KW Suspensions
Porsche 993 RSR - BMW E46 M3
Old 10-22-2009, 09:19 AM
still available
Thatcher
Old 10-22-2009, 11:41 AM
skatinjay27's Avatar
you should try ls1tech.com
those wheels will fit 4th gen camaros and firebirds good and wont need any adapters like the earlier ones will need.
AJ
Old 10-22-2009, 11:54 AM
Thank you for the tip. I just registered for LS1Tech and tried to post them up for sale but it says I have insufficient privilages.
Thatcher
Old 10-22-2009, 12:09 PM
o yeah i forgot they have a 60 post min. to make posts in the for sale section.
I got ya!
http://www.ls1tech.com/forums/lsx-pa...l#post12401964
AJ
Old 10-22-2009, 04:42 PM
Roblee67 Roblee67 is offline
Can you change the backspacing??
Robert Lee
1968 RS Camaro
2001 SS Camaro
Old 10-22-2009, 05:51 PM
I got ya!
hey thanks, i really appreciate that!
Yes - the backspacing can be lowered by adding a spacer or adding a wider outer lip, or it can be raised by adding a wider inner barrel or adding a narrower outer lip.
Thatcher
Old 10-23-2009, 05:49 PM
zbugger's Avatar
zbugger zbugger is offline
Damn... I wish I had the money for these. They'd be perfect for the '00 Z28 I just got. Best of luck with the sale.
Lost in a hopeless world on a path that wanders aimlessly and endlessly... As if it really even mattered.
