Old 10-24-2009, 01:18 PM
camcojb camcojb is online now
I was wondering about that Jody... you guys have quite a bit of "blow by" with the cylinder pressures you're running?? Would it just blow past the rings and create too much crankcase pressure to have it be "passive" like this (mine)?
I love these forums for exactly this kind of stuff - learning by osmosis...
forced induction engines, even with a good ring seal, by their very nature will have more crankcase pressure than a good condition n/a setup. I don't think under boost your way would work in a forced induction setup, but it's a great option for n/a, and am glad you posted about it.
Old 11-12-2009, 05:11 PM
Y-TRY Y-TRY is offline
I've often wodered why the fuel-pump block-off wasn't used more for this. I assumed it was because there was too much oil going through there.
Old 11-12-2009, 05:18 PM
It works great for me! But I don't have a forced induction engine either! As Jody explained - those engines just have to much crankcase pressure... but in my NA motor - this solved a nasty little oil drip that drove me crazy.
