Old 11-11-2005, 12:07 PM
69MyWay's Avatar
69MyWay 69MyWay is offline
Tom,
Can you elaborate on the oiling system for these turbos?
Old 11-13-2005, 07:23 PM
PairOf69's PairOf69's is offline
Dude a twin turboed LT5 is my dream powerplant!...oh the fun I would have in that thing Hey 69MyWay you basicaly live next door, good to see some fellow central Floridians
Old 11-14-2005, 02:14 AM
69MyWay's Avatar
Old 11-14-2005, 09:26 AM
TOM NELSON TOM NELSON is offline
Default Tom
Its a standard deal pressure oil in with a -12 drain line to pan there high enough to drain.
Old 11-14-2005, 04:21 PM
Streetking's Avatar
Streetking Streetking is offline
Sweet, I had one of the 4 LPE twin-turbo ZR1's built. 767 rwh on pump fuel..
SW
Old 11-15-2005, 06:12 AM
Bowtiguy Bowtiguy is offline
Tom, I've got a 91 LT5 motor just waiting for your teaking for my first "real" project. It already sports LPE heads, intake and the larger throttle body. I'll be following your progress on the 91 Z you are working on now. I',m not dropping into a vette so space won't be a problem.
I picked up a 6 stage weiss dry sump with the same specs as the ZR1 oil pump and am concidering running that too. Did you guys ever consider a dry sump system for the 91 or is space a limiting factor? it doesn't look that difficult to integrate once teh oil pump internals are removed so teh feed line to teh stock pick up location in the block still gets oil to that beautiful crank first.
