Old 11-28-2009, 06:18 PM
suite67's Avatar
suite67 suite67 is offline
Default Thanks
Thanks for the kind remarks, guys. Any suggestions on the stance?
Old 12-02-2009, 10:38 PM
fleetus macmullitz's Avatar
fleetus macmullitz fleetus macmullitz is online now
More specifically?
Looks outstanding by the way.
Old 12-03-2009, 06:28 AM
94snglturbo 94snglturbo is offline
i think the stance looks gret.. but would like to see more pics alittle closer of the car
Old 12-03-2009, 11:09 AM
Josh69 Josh69 is offline
First off, she's absolutely gorgeous! I think by your inference to the stance, you may feel that it sits a tad high? From what I recall, the Hotchkis package is around a 1" drop. It'll probably settle a bit, and the '67-8's are tough to get a real tucked look due to the round arches. The wheels are spot on for the car's style though, I like it!
You might cut a coil in the front and do a 1" lowering block in the back. I am in the same boat....mine is a '69 though and the fender design helps. My front sits higher than I would like, but the back is OK. I may cut a coil, I used Hotchkis 2" drop BBC springs since I have an iron headed Pontiac motor and it's heavy as sin.
1969 Firebird, Black w/Parchment Arizen interior, 383 Pontiac Stroker (350/428 crank), TKO600, Moser 12 bolt, 18" TTII's, Hotchkis, GW, DSE, Speed Tech, Vintage A/C, etc.
Old 12-03-2009, 11:37 AM
70rs's Avatar
70rs 70rs is offline
Have you thought about a bolt in coilover conversion in the front and a set of DSE dropped springs in the rear?
You would get a better stance and gain much better handling at the same time with the new components. Not to mention it's very easy to do and the least expensive upgrade.
Old 12-03-2009, 11:45 AM
redfire69's Avatar
redfire69 redfire69 is offline
Looks great! Wheels are dead-on awesome!
Ron
69 Camaro Redfire
Old 12-10-2009, 09:27 AM
suite67's Avatar
Default Thanks
Originally Posted by 68LS1 View Post
Red 1st Gen convertible? Gotta luv it, looks great
I might be biased though
Here is mine https://lateral-g.net/forums/show...t=18143&page=2
Thanks for the compliment. Your Camaro looks great! I almost went with the same wheels - they look fantastic. What did you do to the front suspension to get the front wheels tucked so well?
