View Poll Results: Which Trans is best for my '69 Firebird?
TKO 500 5 1.43%
TKO 600 91 26.00%
T-56 195 55.71%
Richmond 17 4.86%
Other 42 12.00%
Voters: 350. You may not vote on this poll
Old 12-16-2009, 06:59 PM
BeCool68's Avatar
BeCool68 BeCool68 is offline
My vote is for the new Richmond 5 speed with over-drive and Long Shifter.
Don't get me wrong i think the TKO is a great tranny too.
I went with the Richmond to handle the torque i am putting to the ground from the 540 BB camaro.
Also was a very easy install and shifts good for me.
Just my humble thoughts. gb
Old 12-16-2009, 07:33 PM
66LS7's Avatar
66LS7 66LS7 is offline
Default Tremec
I have had several standard transmissions & have found that the T-56 does eveything I need it to. The most recent version of the T-56 trans I'm using is the Magnum & am very pleased with the results.
Randy(D&Z Customs LLC.)
[email protected]
1-262-347-9741
Old 12-16-2009, 07:39 PM
Okay --- That's 4 votes for the Richmond.... and how many for almost ANYTHING else..... LOL
Old 12-17-2009, 07:16 PM
BeCool68's Avatar
Greg, Looks like TKO is your Tranny of Choice!
Old 12-17-2009, 07:17 PM
RAnthony97 RAnthony97 is offline
My vote is for the TCI 6x Six-Speed GM 4L80E Auto with paddle shifter.
Old 12-20-2009, 10:41 PM
Cool tranny but it weighs as much as a truck and will suck up a butt load of snort.
Old 12-22-2009, 12:28 PM
Ron Fox's Avatar
Ron Fox Ron Fox is offline
[email protected]
1-262-347-9741
Randy, what type of car did you put the magnum in? Did it fit right in or did you have to modify?
Thanks.
Ron
1969 Firebird, 4-speed Coupe
If GOD is for us, then who can be against us!
Old 12-22-2009, 12:29 PM
Ron Fox's Avatar
Did you have to modify tunnel?
Ron
Old 12-22-2009, 06:03 PM
BeCool68's Avatar
Ron, we did not have to modify the tunnel, slipped right in.
Very easy install. I believe the new Richmond over drive tranny uses the Richmond 6 speed case, i believe thats what Richmond told me is, so requires a shorter drive shaft. This transmission and shifter are a little pricey compared to some, but i needed something this strong after breaking 2 transmissions before.
I run 755 lbs of torque with my camaro, i have pushed this transmission hard, it truly is bullet proof and runs great on the road coarse. I believe the warranty rating is for 600lbs of torque according to Richmond, granted i do not run slicks so traction is limited but with the DSE Quadralink it does still bite hard.
I run a 308 rear Richmond gear and a 289 first gear in the tranny and .77 in 5th. At 70 mph i am around 2300 rpms's with a 315x17x35 rear tire and allows me 15 miles to the gallon when i keep my foot out it.
Transmission does whine a little but not bad, i have been very happy, with great support from Richmond.
Old 12-23-2009, 08:51 AM
Ron Fox's Avatar
Are you running a Hurst shifter? Do you have a console?
Can you hear the whine of your transmission over the roar of your motor?
Thanks.
Ron
