Old 01-14-2010, 06:58 PM
70rs's Avatar
70rs 70rs is offline
Uh, yeah! What he said ^^^^^
Old 01-14-2010, 07:03 PM
70rs's Avatar
LT means loaded. I can't remember if LT replaced the Z28 in 73 or if it was just 74-76 as the top of the line camaro.
GM still uses LT as meaning loaded. My 02 Trailblazer is an LT. The only thing higher is LTZ. Mine's loaded with leather and all that nonessential but ok I guess stuff
Nice find. Did the child seat come with it as well?
Correct, LT was a trim level. Currently there are 1-LT. 2-LT, 3-LT on many of the cars and trucks from GM as well as LTZ.
On your Camaro there was only one LT designation, it was added to the Z package or any of the other camaro packages as well. It later became the Berlinetta model I think.
I don't need a picture of the trim tag Trey, just write down everything in order line by line, I can get it all from there. I will be able to tell you everything about it (drivetrain, interior/exterior colors and trim...) If you include the VIN I can tell you more.
Eric
Old 01-14-2010, 07:10 PM
Heck Eric -- I don't need no stinkin' numbers!
Trey -- Here's what you got!
It's a primer black paint - reddish/orange velour interior - with a 454 bb and automatic..
TreySmith's Avatar
TreySmith TreySmith is offline
I will get onto that tomorrow. Going to go over it completely and check it for rust first. When we swapped out the tire I noticed the calipers looked almost new. All of the body panels are horribly aligned so that needs to be taken care of. I shouldn't have any problems with the engine. He said it was swapped in 3 years ago and they had it running. It was the engine out of his truck and he said he never had any problems with it.
School is out Monday so I will have a full day to work on it. What should I use to wash out the tank? Would water be ok? I am guessing no. I was gonna clean it out along with the lines. Then check the oil and try to crank it up.
Old 01-14-2010, 07:15 PM
70rs's Avatar
NO,,water is not what you want to use. Just drain it (keep the EPA in mind.... ) and let it dry out, if there is any rust flakes you can dump them out too. Check it out with a flash light inside, if you need a new one they are really cheap for a carb'd version. You can flush the lines with slovent if you think they need it, but again new ones are reasonable if your are shot.
The numbers when ever you want. Just shoot it over in a PM or email.
Old 01-14-2010, 07:48 PM
awr68's Avatar
awr68 awr68 is offline
Good for you Trey! I really appreciate your love for these older cars! And this one will be a lot more affordable than a Mopar!! But still have great resale!
Tony
'68 Camaro
Old 01-14-2010, 07:55 PM
67rstbkt 67rstbkt is offline
Nice, congratulations on the new purchase. Are you going to reupholster these seats as well? And yea, make some lists. Hopefully you won't find too much rust.
Rusty Bird Build Thread:
https://lateral-g.net/forums/showthread.php4?t=18566
Old 01-14-2010, 07:59 PM
TreySmith's Avatar
Yes but I am probably going to swap them out for Camaro seats first, what's in it now is from a 79 or so Trans Am.. I am going to make a video tutorial for reupholstering them instead of the picture tutorial I made for the T/A to help some people out.
Old 01-14-2010, 08:47 PM
nvr2fst nvr2fst is offline
Arrow
Dont worry Trey, beauty is in the eye of the beholder
Old 01-14-2010, 08:55 PM
I wasn't making fun of the project - I was poking fun at ERIC and his decoding.
Trey knows I like his projects!
Makes me re-live when I was a young-un and doing this kind of stuff... but back then we didn't get much help. I think my dad just kept his mouth shut and hoped I'd bury myself... but much to his chagrin - I actually got this stuff up and running and usually was able to turn a buck and move on!
