Old 01-25-2010, 09:55 PM
awr68's Avatar
awr68 awr68 is offline
keep it clean guys!
Tony
'68 Camaro
Old 01-25-2010, 10:06 PM
customcam's Avatar
customcam customcam is offline
Why were the posts deleted?
Old 01-25-2010, 10:27 PM
70rs's Avatar
70rs 70rs is offline
Sorry for the detour there Chad. I hope you find a way to get the results you are looking for. The truck will be killer either way.
Eric
Old 01-25-2010, 10:55 PM
awr68's Avatar
It got way off topic and should have been taken to PM......
Tony
'68 Camaro
Old 01-26-2010, 04:59 AM
ccracin's Avatar
ccracin ccracin is offline
Now that we are back on track, I'm still looking for some more suggestions. Thanks.
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 01-26-2010, 06:54 AM
Chad we have painted alot of motors haven't had one crack or peel yet. Your going to want the surfaces to be clean! And I mean clean no silicones, oils, water, etc. No depending on how smooth you want you can de-burr the casting marks, etc. If it's just a color you want. Apply a good etch primer, followed by a sealer, then color, clear / single stage.
Most paints and clears will take close to 500 degrees so unless your motor has an issue the paint will last. We use Spies/Hecker paints and clears fyi.
Jeff Allen
J2 Speed and Custom
