Old 11-23-2005, 09:28 AM
tndude tndude is offline
Originally Posted by 68protouring454
those jacks are 30 or so bucks at harbor freight, not sure what your paying for the winch but it cannot be too much cheaper, check them out, i can give you measurements etc
jake
I don't know why I did not think of Harbor Freight and we have one here in town. Previously, I check online with different providers and they were not as cheap as Harbor Freight. Many thanks and YES I'm going to use the hydraulic jacks now.
QUICK UPDATE : during my lunch hour I ran to harbor freight and was going to get two 3 ton hydraulic jacks for $39 each. To my surprise they had the 8 ton jacks on sale for the same price. Again, thanks for the tip Jake.
Old 11-23-2005, 01:51 PM
68protouring454's Avatar
Default hf
cool, glad you found them.
Looks like yours will be better then troys.
Old 11-28-2005, 12:29 PM
why not use hydraulic bottle jacks, way safer then winches and works nicer too, here is a pic. this is a buddies andn i copied his and made one myself, pics of mine are too big to post.
jake
Jake, how did you build the pipe that turns on the vertical square tube? Specifically, my question is this, does the part that bolts to the car slide out of the round pipe or is it locked in it? This is hard to explain so let me know if you do not understand what I'm asking.
Old 11-28-2005, 01:11 PM
MaxHarvard's Avatar
*whistles*
dang man, nice!
Old 11-28-2005, 01:18 PM
Ummgawa's Avatar
Ummgawa Ummgawa is offline
And how about a list of materials/lengths and measurements/etc.? Share man share!!
Jim
Old 11-29-2005, 06:40 AM
Default tndude
the part that attaches to the car has some 3.5 sch 40 pipe welded on to it about 11 inches long, the main upright that has the tube that slides up and down on it has a peice of 4 inch sch 40 pipe 9 inches long weldeed onto it, pipe is measured by the inside width, so the 3.5 inch is really around 3-3/4 to 3-7/8 outside(i can get exact measurement) so it fits damn near perfect into the 4 inch, just enough it turns nice.
the key is to have the peice that attaches to car be adjustable up and down as this will zero balance your car so it turns over very easy, all cars are real bottom heavy so you need to get that weight up near the pivot point, i am welding a manual adjuster on mine to adjust this as i used my engine crane to do it before.
also for jacks let me know your upright height so i can tell you tube used to go off top of jack then to adjustable height slider so that you can put it way up and down and not run out of jack doing it.
also yes the pipe does slide in, and is not locked in i have one 1/2 nut and bolt that locks it in place once car is in position. also it is very important that you center connecting bar peices fit very tight, or the end uprights will sag in big time, any little play will turn into big play at the ends.
Old 11-29-2005, 02:13 PM
Old 11-29-2005, 02:20 PM
Sure thing my friend. Over the holidays, I'll draw up some plans.
Old 01-16-2006, 06:10 PM
Here is an update pic. Going slow but making progress….
Old 01-16-2006, 07:26 PM
Ummgawa's Avatar
Thanks...You da man.
Jim
