Old 02-18-2010, 06:15 PM
zcrz zcrz is offline
I know...its just I have a sh*t load of money in this car and hardly drive it for some reason....takes 10 minutes to warm up,wifey says its stinky, which it is and I just want to make it better to drive. I think this FAST setup may be what I'm looking for...money is always an issue for toys...
Old 02-19-2010, 08:24 AM
94snglturbo 94snglturbo is offline
do the ls motor.. im doing a ls2 motor. and i already had a badass 355 425hp fully custom motor. im doing the swap for drivability, reliability, gas mileage.. im also going to turbo the motor
Old 02-19-2010, 08:55 PM
I agree with Todd and Greg.
I was thinking of going with the Fast EZ but my motor makes 610 hp and that was at the top limit of the EZ, so I went with XFI set up. Now you can get over 600 with the EZ.
I thought of going LS but instead of changing some things I would need to change almost everything . My trans, clutch, headers just to name a few. Which I would have taken a beating on. If you have a good motor and drive train put the EZ and have a sweet running ride. I have a TBI on my 99 Tahoe and the throttle response is great and thats a 250 hp truck.
Old 04-16-2010, 09:58 PM
So.......... any decision on which way you're going??
Old 04-17-2010, 02:34 PM
6D9 6D9 is offline
I say EZ EFI . Lots of hidden costs for the LS swap that will nickel and dime ya. Dont get me wrong I would LOVE to have a built LS but my current combo runs killer and I would loss my butt trying to sell it. I may go for the same EZ EFI set up myself.
69 Camaro
491 BBC
TH400/GV OD
Currie 9"
Rushforth Livewires
Old 04-24-2010, 10:55 AM
Probably gonna try the EZ shortly. I havent been thinking about it much lately.
Any of you guys get the Fast setup installed yet?
Old 04-24-2010, 06:40 PM
I've got the ECM and harness -- and the Inglese 8 stack intake manifold - but it will be a week or so before the engine is on the dyno and I get to actually use the EZ EFI.
Old 05-17-2010, 10:13 PM
Ran my new 406 on the dyno today -- with the new Inglese intake and my Imagine Injection throttle bodies - 36 lb injectors - and EZ EFI controller.
I can tell you that once I got all the throttle bodies sync'd up (there is some adjustment to make sure the blades are all set "equally").... in less than half an hour - the motor was making power pulls -- and every run got better and better - until each pull was exactly the same. The A/F's were right on the money - the exhaust temps were within 100 degrees of each on each cylinder - and the motor ran GREAT!
550 TQ @ 4600 rpms - 525.4 HP @ 5600 rpms
AMAZING STUFF I TELL YA! AMAZING... and I've been messin' with EFI for 10+ years now... this is so simple a friggin' caveman could do it!
And I'm talking a fairly big cam - with 8 stack EFI...
Old 05-17-2010, 10:18 PM
Are you sure you didn't leave some top end hp on the table Greg? Peak torque at 4600 doesn't jive with peak hp at 5600.
Old 05-17-2010, 10:46 PM
It does - when you use baby heads on big cubic inches....
The Dart Pro 1 - 180cc heads are going to kill HP at higher rpms. But that was the way we planned the motor. It's a HOT ROD motor... I wanted big TQ down low in the band -- and was willing to toss the big bragging HP numbers in order to get there.
My Nomad weighs 4023 pounds - runs a 700r4 - and 3:70 gears... Tranny shifts about 5500 rpms... I have smallish tires in the rear. It burns rubber but won't set any 60' times! LOL
I wanted a "smoothish" running and torquey motor. The cubes and small heads (fast air flow) - give me the torque - but the small heads are going to kill the HP numbers. Here's something to look at:
RPMS TQ / HP
3286 478.3 / 299.3
4000 513.4 / 391.0
4600 550.0 / 481.7
4900 541.5 / 505.2
5100 527.6 / 512.3
5500 500.4 / 524.0
5900 455.4 / 511.6
6200 419.3 / 495.0
