Old 04-06-2010, 04:47 PM
chevyhector's Avatar
chevyhector chevyhector is offline
Hey 732ndgen, I will ask if you can apply boost to a set-up like this. OK?
Originally Posted by 732ndgen View Post
dou you know if you can apply boost to these
Love your Family, and LIFE ! God bless
Old 04-06-2010, 04:48 PM
Originally Posted by chevyhector View Post
Hey Vegas,
That’s gonna be your new nick name "FOF" (function over form) what does that even mean in this situation ??? It does gain HP, it DOES allow C O L D - A I R into the engine ! But that's ok, my 40+ hp gain will keep you in the rear view mirror J/K ! All in fun right !?!?!
Of course man....
Old 04-06-2010, 05:01 PM
phillym5 phillym5 is offline
Of course man....
Im not sure what this "cold air intake" thing is you guys are discussing.... i have a couple "air compressors" that will leave both you guys in my rear view!! hahaha..!!!!!!
Old 04-06-2010, 05:02 PM
Bring it on ......
Old 04-06-2010, 05:45 PM
This "talks" to me....
That cold air intake looks like something Sears would sell....
Old 04-06-2010, 06:08 PM
skatinjay27's Avatar
i prefer to see the tennis balls! NOW that talks to me!
AJ
Old 04-06-2010, 06:10 PM
Skatin'
Old 04-06-2010, 06:15 PM
G-Body's Avatar
G-Body G-Body is offline
Dont care for the ducting, looks to import looking!
Old 04-06-2010, 09:24 PM
Rod P's Avatar
Rod P Rod P is offline
40 HP? if cold air did that much, just take the hood off
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 04-07-2010, 04:58 AM
evilzee28 evilzee28 is offline
Originally Posted by Josh69 View Post
If it effectively seals to the hood, then it appears that the air cleaner will draw from the large opening between the radiator support and front fender which is open to the front of the car. So in essence, it'll be pulling cold air from the grille ahead of the radiator.
We used to run these style of cold air kits on BMW's. They draw from a tube below the front bumper. Similar idea. I'm surprised nobody has done it yet.
Cowl style cold air induction is great, problem is usually the expense, cutting holes, sealing the shroud to the hood, etc.
If this kit is reasonably priced, it would be effective if the hat doesn't impede flow. But, looking at their other cold air kits, they'll want $400 for it then it's not so appealing.
Sorry but I don't nescessarily agree with the above statements but I do agree with vegas69 that it's form over function ,IMHO it's just another bling item to add to your car. The BMW's may be drawing air from under the bumper, but it's drawing unimpeded cold air directly from the airstream in front of the car.
Sure there's a rubber seal fitted to the top of the shroud on this kit to seal the shroud to the hood, but the radiator core support doesn't even have a close out panel that would help keep the airflow in front of the rad, which might allow it to flow past the airfilters to get some colder air. The top of the radiator core support should also be sealed to the hood to keep the colder air in the required area. So, as it is, the filters aren't "sealed" to just cold air, as a ram air sytem does. Notice the word "Ram air", it's not just cold air that works on these things but a forced induction as well, with the airflow being picked up at the high pressure area at the base of the screen & it being "forced" into the carb through the ram air hood. OK not everyone wants a ram air hood, but this system is flawed at best. Surely it would be far better to run the pipework through the radiator core panel & fit the filters in front of the core support "area" rather than having the filters in the engine bay, or is that just for "looks"?.
As you say, the "hat" does look too small to flow enough air, so it may actually impede airflow. Sorry but this set up doesn't do it for me at all, heck, you can't even run a battery in the stock position.
I'd still be interested to see side by side comparisons of this set up against an original cowl hood, ram air system, sometimes the wheel doesn't need reinventing
cheers...Nige
