Old 04-08-2010, 08:32 PM
I doubt you'll get to 400. Remember, the LS6 only had 400 stock and it used 10.75 compression and was 5.7 liters with the difference being 100% bore size. Your 317s are basically low compression LS6 heads. I'm afraid those heads and that cam will not allow the charge to be compressed enough for a good burn. Honestly, it's beyond my knowledge but my gut and experience tells me you need minimum 10:1 with that cam on this type engine.
My suggestion would be to approach this from a different angle. I'd ask around and say what can I do to build an 87 octane engine and state what parts you have available. I'm assuming you still have the 5.3 heads. It may turn out that the best idea is to use the 5.3 heads and a different cam. I know it adds money to the build but if you miss your mark the first time, you'll be adding time on top of costs to get it right.
Also do not forget that if you are using an automatic transmission behind the engine you have tremendous tuning abilities with the drive train to make all your ponies work for you. Manual guys don't have that luxury without getting stupid expensive with gear changes in the transmission. Use the capabilities of the torque converter and electronic control of the transmission to your advantage. I'd rather go fast than have a dyno queen
Old 04-08-2010, 09:41 PM
70TWO NOVA's Avatar
70TWO NOVA 70TWO NOVA is offline
You may be right, but using the 317 heads (which ive decked to 66cc, ls6 were 64cc) and a set of flat top 4.8l pistons my SCR is about 9.8:1. I know its not quite the SCR of the LS6 (which was actually 10.5:1) but its close. That combined with the same top end (317s flow better than 243s down low) and other bolt ons that the factory ls6 didnt have like long tube headers and better flowing air intake system and a good tune should get me very close to the 400 mark. If I dont quite get there I wont be heart broken, just a goal after all
Brian Miller
-1972 Nova
-1968 Camaro
-1967 C-10 step side 4x4
-2000 Dodge Dakota
it'll buff out........
