Old 04-29-2010, 06:22 PM
J-440's Avatar
J-440 J-440 is offline
Ok, ya'll are the pros. I'll order the correct fittings and thanks again.
68 Charger, 440SC, EFI, 6-speed
Old 04-29-2010, 06:55 PM
Buffaloed another one!
Old 04-30-2010, 05:47 AM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
Originally Posted by killer69 View Post
if it were me, i would get rid of the thermostat and find one with -12 fittings.if not leave it out of the system, unless your in the artic?? even the filter mount shold have -12 fittings.
it is all about less restriction ,as Greg said you are adding a ton of restriction to the system and you really need to reduce it any place you can, even the fittings you use are important do not use brass 90 deg fittings, i'm no plumber but if i remember correctly every 90deg bend reduces flow by 25% and use a good cooler like a Earls or Setrab ( setrab makes the earls ones)
i am just in the process of putting my cooler system together today.
but then you run the risk of keeping your oil temp under 200* which is something you don't want to do.
for the money i have in this cooler adapter ($16) i would really like to use it. it was off a '07 Z06. i just cut the rubber lines off of it and installed -8 hard line adapers.
i don't use brass fittings so we are good there.
Old 04-30-2010, 07:32 AM
My Zl-1 block from GM Racing has -10 receptables. I was going to use -12 until I found that out. I had no room for adapters and a -10 to -12 adapter fitting wouldn't clear the block recess. I would've needed to turn down the hex. My engine builder said -10 was fine if the hoses were kept reasonable length. I'm plumbed from the oil pump, through my heat exchanger, then back into the block through the filter. That's how GM racing recommended. The cooler is -12 with -10 adapters.
As far as oil temp goes. Even with a 180 stock coolant t stat I can't get any oil temp in the engine until I cruise stop light to stop light for some time. I have close to 10 qts of oil in this thing and it does a great job cooling the engine. I was hoping the heat exhanger in the radiator would warm up the oil but it seems to cool the coolant when cruising down the freeway. When I get into traffic then it works perfect with coolant temps around 180-190 and oil temps 10-20 degrees warmer. I found on the race track at el toro that coolant temps would be about 190-195 and oil temps of 235-240. The minute I got to my cool down lap the oil temp dropped to 210 before I got back to the pits. Again, I'm prepared for worst case scenario. For me, that's road racing for 15-20 minute intervals with countless pulls over 6500 rpm. It's probably a little to much oil in the system for a lazy Sunday afternoon cruise. That's ok, I'll change the oil a little more frequent and make sure I get some heat in the engine when I drive it.
Old 04-30-2010, 07:41 AM
You'll just have to race more on the streets...
