Old 08-03-2010, 09:19 AM
Revved's Avatar
Revved Revved is offline
Default FAST XFI does offer traction control options
I've never used it but the FAST XFI system does offer traction control. Here is the overview text from their help section.
32.0 Intelligent Traction Control
32.1 Overview
There are two modes of Intelligent Traction Control that can be used in your XFI™. One is called Heuristic Mode, and the other is called PA Mode. Each mode can be used separately or together to reduce or eliminate a loss of traction which can occur due to any number of reasons such as limited tire size, suspension issues, or track conditions. Both modes utilize a speed sensor to monitor driveshaft RPM and are easily set-up using a simple 2D graph. The fact that both modes rely on driveshaft speed instead of other methods that utilize engine speed (RPM) to base their traction control on makes this much easier. The reason for that is you no longer have to ‘chase’ plots on a graph that are constantly affected by other factors such as gear changes, torque converter or clutch slippage, or anything else that can affect engine RPM and the rate at which it changes. Those variances don’t occur with driveshaft speed. FAST™ has once again come up with a simpler, easier way to get you down track or around town.
