Old 05-11-2010, 08:15 PM
I think Chrome Molly is only ever used where WEIGHT is a major factor -- otherwise - why bother... DOM is fine for most of us...
What book Chad! You only got thru page one!
Old 05-11-2010, 08:21 PM
ccracin's Avatar
ccracin ccracin is offline
That's all I could do, I only type with 2 fingers!
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 05-12-2010, 08:33 AM
Blake Foster's Avatar
i would say your 100% correct on this one.
CM is typically 30%-35% lighter that .134 wall dom. so if you had 80 feet of material in a road race cage you might save 50-80 lbs (just guessing here) the DOM is 1/2 the cost of CM if not less. the labor savings is probably 1/2 for the install
that being said i have 3 lengths of CM sitting here waiting for the new project to arrive, but if it wasn't on the rack i don't think i would spend the extra $$$ to use it. if i was building a Comp Eliminator or Prostock car then there wouldn't even be an option it would be CM. but a track day car or super class car, there are alot of other places to loose 50-80 lbs.
Blake Foster
www.speedtechperformance.com
Old 05-12-2010, 10:08 AM
ironworks's Avatar
I know I could stand to lose more weight personally on my body, then I ever could with a 4 or 6 point cage. I bet you lose more weight with Lexan windows or Anvils carbon parts is you have a 1st or 2nd gen camaro.
Old 05-12-2010, 10:58 AM
RickM415 RickM415 is offline
ok so lets say i go dom tubing then 1 3/4 .134 would get me in to all the pro-touring events ?...and where to get it in nor cal ?
Rick
1969 camaro rs ss
ls3 twin turbo 6speed will be done when the browns win a Super Bowl lol
Old 05-12-2010, 05:45 PM
Apogee Apogee is offline
Based on what I've seen, 1-3/4" x .0120 DOM mild steel will get you onto most tracks, but the design has to be compliant as well as the material. If you go too thick on the wall, you limit your bend radius options for conventional mechanical die/follower type tubing benders, hence the reason I wouldn't exceed .120 on the wall thickness.
Tobin
www.kore3.com
Old 05-12-2010, 06:33 PM
ok so now that we got the material figured out ....where can i get it
Rick
1969 camaro rs ss
Old 05-12-2010, 06:41 PM
ironworks's Avatar
Define Pro-touring events? I think Silver state has the biggest mandate. The single day non competitive events should not require anything I believe.
Old 05-12-2010, 06:45 PM
eville's Avatar
eville eville is offline
Check these guys in Hayward. I bet they can hook you up.
http://www.naylorsteel.com/
Steve
'68 Camaro - 355", TKO600, SpeedTech Arms, ATS-AFX Spindles, Hotchkis Springs, Forgeline Wheels, C5 Brakes (Kore3), Holley Terminator EFI
Check it out Here
Old 05-12-2010, 07:39 PM
nvr2fst nvr2fst is offline
SIVER STATE CHALLENGE
ROLL BAR SPECIFICATIONS
Roll Bar: A Roll Bar is mandatory in the Grand Sport Division, and recommended in Grand Touring
and Touring.
Basic Design Considerations: The basic purpose of the roll bar/roll cage is to protect the driver in case the vehicle rolls over. This purpose should not be forgotten.
A.
B. C.
The top of the roll bar shall not be below the top of the driver’s helmet in a closed car and a minimum of two (2) inches above the driver’s helmet in an open car when the driver is in the normal driving position. It shall not be more than six (6) inches behind the driver.
The two vertical members forming the side of the hoop shall not be less than fifteen (15) inches apart, inside dimensions, at their attachment point to the uppermost chassis member.
An inspection hole of at least 3/16-inch diameter must be drilled in a non-critical area of the roll bar member to facilitate verification of wall thickness. This should be at least three inches from any weld or bend.
D. Cars with factory built or factory reinforced roll structures may be allowed in the Grand Sport Division. They will be evaluated on a per car basis. The decision of the Event Director will be final.
Material: The roll bar hoop and all braces must be of seamless DOM (Drawn over Mandrel) mild steel tubing 1010 thru 1025 or alloy tube steel SAE 4130 chrome moly. Proof of alloy, leave unpainted. All NEW roll bars must meet or exceed this requirement.
A. The size of the tubing to be used must be determined on the basis of the weight of the car. (pg. 16)
Fabrication: The main vertical hoop must be one continuous length of tubing with smooth mandrel bends and no evidence of crimping or wall failure. No bend radius will be smaller than 3 times the tube diameter.
A. All welding must be of the highest quality with full penetration. All attachments points must be welded 360 degrees around the tube. Welding must conform to American Welding Society codes.
B. It is recommended that gussets should be welded at the junction of any tubes. Bracing: it is recommended that braces be of the same size tubing as used for the roll bar itself.
A. B.
C.
All roll bars must be braced in a for or aft direction with the brace attached within six (6) inches of the top of the hoop, and at an angle of at least thirty (30) degrees from vertical.
It is required that a diagonal brace be used to triangulate the main hoop, and it is highly recommended that this brace be attached at the top on the driver’s side and attached to the bottom on the “passenger” side. See Exhibit A
A headrest is required if not part of the seat.
Revised 1/2010 - Page 15 -
6.
7.
8.
9. 10.
11.
Mounting Plates: Roll bars and braces must be attached to the frame of the car whenever possible. Mounting plates must be used for this purpose. When the main hoop is attached to sheet metal, such as a floor attaching point for unibody cars, the mount plate must be at least 36 square inches (6” x 6” plate) on both sides of the sheet-metal or that provided by the manufacturer. If possible the plate should extend up the vertical wall.
A. A minimum of double-nutted 3/8 inch grade 5 bolts for self-locking or welded nuts shall be used to bolt to the car. No bolts are needed if the bar is welded to the car’s frame. Plates welded to the floor must be at least as thick as the bars tube.
B. In the case of cars with unitized or frame less construction, mounting plates must be used to secure the roll bar structure to the floor of the car. The important considerations is that the load be distributed over as large an area as possible. Plates bolted to the floor must be at least 3/16 inch thick and be placed on both sides of the sheet metal. A back-up plate of equal size and thickness must be used on the opposite side of the panel with the plates through- bolted together.
Removable Roll Bars: Removable roll bars and their braces must be very carefully designed and constructed to be at least as strong as a permanent installation. If one tube fits inside another to facilitate removal, the removable portion must bottom on the permanent mounting, and the mounting hardware used to secure each joint must be grade five (5) or better. It is recommended that the telescope section be at least eight (8) inches in length.
Installations on Cars of Space Frame or Frame less Design: It is important that the structures be attached to cars in such a way as to spread the loads over a wide area. It is not sufficient to simply attach the roll bar to a single tube or junction of tubes. The roll bar must be designed in such a way as to be an extension of the frame. Considerable care must be used to add as necessary to the frame structure itself in such a way as to properly distribute the loads. It is not true that a roll bar can only be as strong as and single tube of the frame.
On cars of frame less construction, consideration should be given to using a vertical roll bar hoop of 360 degrees completely around the inside of the car, and attaches with suitable mounting plates. This type of roll bar then becomes a substitute for the frame.
Other Designs: Deviations from the above will be considered. Roll Bar Padding: Roll bar padding must be used to protect the Driver/Navigator in all areas of
possible contact.
Minimum Tubing Sizing: The size of the tubing to be used shall be determined on the basis of the weight of the car.
Under 2200 lbs. 2200 to 3000 lbs.
3000 to 4000 lbs Over 4000 lbs
DOM 1.50” O.D. X .095 wall mild DOM 1.50” O.D. X .095 wall alloy
DOM 1.75” O.D. X .120 wall mild DOM 1.75” O.D. X .095 wall alloy
DOM 1.75” O.D. X .120 wall mild or alloy DOM 2.00” O.D. X .120 wall mild or alloy
Revised 1/2010 - Page 16 -
XI.
ROLL CAGE SPECIFICATIONS
4
4
3.
4.
5.
1. 2.
Roll Cage Division Requirements: A roll Cage is mandatory in the Super Sport and Unlimited Divisions.
Super Sport & Unlimited Division Requirements:
A. The cage may be removable or may be permanently welded, or any combination thereof, providing that all aspects of the cage meet these rules.
B. A NASCAR style roll cage is highly recommended.
C. Material, Fabrication, Bracing and Installation specifications are the same as the specifications for a Roll Bar. See Section X, pages 15 & 16 for detailed information.
D. None of the tubing may show any signs of crimping or wall failure. All bends must be Mandrel type
E. One continuous length of roll bar tubing shall be used as the main hoop. The main hoop must consist of not more than four (4) bends maximum, totaling one hundred eighty (180) degrees +/- ten (10) degrees.
F. At least one (1) diagonal brace must be used in the same plane as the main hoop. One end of the diagonal brace shall attach to the corner or horizontal part, of the main hoop above the drivers' head, within twelve (12) inches of the drivers'-side corner.
G. The forward hoops extend from the main hoop (in a forward direction) to the floor by following the roof and the "A" pillar of the car. There must be a bar connecting the two (2) forward hoops at the top of the windshield mounted as close to the roof as possible.
H. The main hoop must have two (2) braces extending to the rear. The braces shall be attached as near as possible to the top of the main hoop, and no more than six (6) inches below the top.
I. At least two (2) door bars on the driver and passenger sides must be used. The top door bar crossing height between the shoulder and elbow may be angular or horizontal. The second door bar should be horizontal.
J. The roll cage shall be mounted to the floor of the car in six, seven, or eight points. All cage attachment points must be mounted to plates.
K. Welded mounting plates must be at least as thick as the tube wall.
L. The attaching points of a bolt-in cage to the body must use reinforcing plates to sandwich the body. At least three bolts are required for each bolt-in plate and the plate must be at least 3/16 inch thick. All hardware must be SAE grade 5 or better with 3/8 inch diameter minimum. All nuts must be held by a locking system, such as lock washer, or jam-nuts.
M. All welding must be of the highest quality with full penetration. All attachment points must be welded 360 degrees around the tube. Welding must conform to American Welding Society codes.
N. All required bars must be made of the same material and meet with at least the minimum specifications for size and thickness.
O. All roll cage surfaces that may come in contact with the driver must be padded with high- density padding such as Ethafoam or Ensolite.
Specification: See Roll Bar Specification for the roll cage fabrication specification. Main Hoop and Braces: The main hoop and support braces should be of the same size.
Minimum Tubing Sizing: The size of the tubing to be used shall be determined on the basis of the weight of the car.( pg. 16 )
