Old 05-19-2010, 11:13 AM
Pantera EFI Pantera EFI is offline
Default Batch Fired vs "once-per-cycle" injector firing
Hi Greg, this is what I do for Bob Ream, I fire the fuel injector ONCE per cycle.
NOT TRUE "need to batch fire without a CAS".
What I do with my EMS is to set it to fire the injector ONLY ONCE per cycle.
I also set the #1 cylinder's firing time to 450 degrees.
This can be quite simple for the "EZ's" eight channels of fuel, just wire the # 1 cylinder channel to #5, then go through the firing order.
What you will observe is a SMOOTH idle, much better throttle response, and a GREAT increase in millage.
Lance
Old 05-19-2010, 11:16 AM
SO.... could I send the ECM to you to have this done??
If so... PM me please.
Old 05-19-2010, 11:17 AM
Lance --
Is the brain box called an ECU - an ECM or an EMS.... or can it be called anything you want to?
I just call it -- Smarter than a Carburetor...
Old 05-19-2010, 11:18 AM
Greg any time table for installing the engine and the first drive or are you doing more to the car?
Old 05-19-2010, 12:14 PM
I have to first UNinstall the Accel Gen 7 stuff... and I also have a new AutoRad core support and radiator/condenser... other than that... it's a simple install.
I tore all the sheetmetal off the front end - so it will be a pretty easy install and wire job (has to be hidden).
Unfortunately - I also am moving my daughter to Scottsdale to start at ASU... and I'm driving her down (taking her Mustang down in the trailer)... so there goes a week.... But I hope to have it all wrapped up by June 15th or so. Gwen is headed for Europe for a couple of weeks - Adrienne will be "gone" and I'll be home all alone...... Should be able to get some serious work done then... ya think?
Old 05-19-2010, 02:28 PM
Sounds like a plan! As long as you don't end up like that kid from the movie. lol
Old 05-19-2010, 02:38 PM
Too late! Been there - done that!
Home Alone 2 this time around!
LOL
Old 05-19-2010, 06:01 PM
Here's the dyno sheet from one pull...
Old 05-22-2010, 10:32 AM
Default Pantera EFI : OK
Hi Greg, I would be able to help when your are ready.
I could ask Brian Macy to send you a calibration file ?
Lance
Old 05-25-2010, 12:22 PM
Josh69 Josh69 is offline
Awesome! I wish I hadn't spent so much on other stuff I sorta needed...I'm looking forward to EFI eventually!
1969 Firebird, Black w/Parchment Arizen interior, 383 Pontiac Stroker (350/428 crank), TKO600, Moser 12 bolt, 18" TTII's, Hotchkis, GW, DSE, Speed Tech, Vintage A/C, etc.
