Old 05-25-2010, 07:22 AM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
Sorry to hear that. Hope it all works out for you in the end.
GOOD LUCK MAN!
Old 05-25-2010, 07:32 AM
Originally Posted by akrapovic View Post
He offered to cover the labor, when he gets time. I just feel kind of retarded letting the guy who messed it up fix it.
I absolutely agree with you! My feeling is - if you couldn't do it right the first time - what makes you think you can do it right now?
On that note: I always have told people working on my stuff - "please don't build my "X" with YOUR wallet. If you have a choice of good, better, and best... I will ask you.. What do you have better than that? That is what I want. Don't try to save me any money.
What I've ended up with - is some very nice - top notch - used parts.
Yesterday I picked up the "OLD" AFR 190cc aluminum heads. I chose to change heads on the latest build to switch from STRAIGHT plug to angle plugs... So I asked the shop to go thru the AFR's and make 'em right. My thought is that I can use them again - or sell them - or give them to a friend that is in need and maybe can't afford them - but "whatever" - I just want them as good as new. The bill was $911 for me to toss them on the shelf - where they now reside next to a nice set of Canfield 220cc heads... They're too heavy to use as paperweights.
Old 05-25-2010, 08:32 AM
Josh69 Josh69 is offline
Hear Hear. I'm in the same boat. First engine was built with a few extra parts leftover, not to mention the rear cam journal plug that came out and oiled down my fresh chassis.
The 2nd build is going on as we speak..this time we're running it in on a test stand to make sure everything is copacetic before it goes back in the car.
Also using a new builder that has a good reputation...which is what the last builder had too.
Argh, if it's not the bodyman, it's the machinists. I swear, the only things that were done right or on time and to my satisfaction were things I didn't pay someone else to do..even though I've missed a few simple things...I usually figure them out quickly...and they don't require pulling the engine out or repainting the car.
1969 Firebird, Black w/Parchment Arizen interior, 383 Pontiac Stroker (350/428 crank), TKO600, Moser 12 bolt, 18" TTII's, Hotchkis, GW, DSE, Speed Tech, Vintage A/C, etc.
Old 05-25-2010, 09:01 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
Okay ladies, y'all tricked me into getting on my sopabox. Well, I had a $12k 509 ci (hence my member name 509 Chevelle) built with AFR 315 heads, fully cnc'd and all, Street & Performance serpentine pulley system and all. Anyway, the motor was a hell of a motor. It ran fine and I bought it from a builder I found on the net. He (the builder) did everything I paid him to. The motor was perfect. No complaints on him. This is where I got screwed. It had a solid roller cam in it and I took it to a "so-called" reputable, local engine builder. Took him my cam specs card to get the valves adjusted. I guess he ignored the cam specs and this idiot cranked down and tightened my springs down too tight which prevented the valves from opening all the way. As a result of this, it flattened out my cam lobes and broke some of the wheels on my roller lifters. I had noticed when I picked the car up from him it sounded very funny which was from the valves not opening fully, but didn't know what it was and kept driving it until the cam went flat. All the internals were fine so I sold the motor to a buddy of mine who fixed it and it still runs fine to this day. Like I said, the motor was built nicely. After this is when I got the LS 6.0.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 05-25-2010, 09:26 AM
chr2002ca's Avatar
Dude, I feel your pain. My brand new GM ZZ454 crate motor spun a rod bearing after 2000 miles at the RTTC event a few months ago. If anybody heard a ticking at the event, that was me, I call it. While people got to parade their cars around the track, I got to watch mine get towed home. Motor of course had to come out. Same results as you, all the hard parts were okay and only the bearings needed to be replaced and the crank polished. It's all back together now. I checked clearances on its way back together in my garage and everything checked out okay so I'm still not sure what caused it. It's had a 6000rpm rev limiter on it since day 1. I took the time to break it in properly, oil prime it, etc. Maybe the engine just somehow didn't break-in properly, oil shortage, bad luck, GM sucks, I suck, I hate cars, etc. I installed an Accusump system so I shouldn't be able to blame it on oil shortage when(not if) it happens again.
So buying a new GM crate motor with a warranty doesn't mean jack sh_t. And then there's my new Bowtie Overdrive Level 3 200 4R that has vented fluid out of the plastic vent tube from day 1(they're still puzzled by that one). The pressure readings look good in all gears(since day 1) and the fluid level is dead on, so I'm most likely going to have to drive to their facility and have them figure out what the problem is. That might have to come out also, who knows. Maybe it's something simple(not with my luck). My new AGR steering box blew up after 50 miles and burned fluid into my pricey ceramic-coated headers, and that was after it had already gone back to the factory once to fix a slop issue. Those are so much fun to replace on a 69 camaro with a big block and 2 inch primary headers. My March serpentine system with proper alignment and Gatorback belts squeaks like hell unless you tighten it too much(water-pump and alternator bearing killer), and then they finally admit over the phone they don't recommend running it with a mechanical fan(funny that's not mentioned in the marketing literature). "Did you try taking the fan off?" No, I didn't, but it somehow stops squeaking when I take the belts off. It's even quieter if I take your pulleys and brackets off too. And the Baer brakes 4-wheel disc kit that are famous for being 'complete' was missing parts and still doesn't have enough brake pressure after 2 different boosters and 3 different master cylinders with plenty of vacuum from the engine. And their brake pads grunted badly on the rears after 200 miles and had to be replaced. And the new Moser 12-bolt leaked, and the Powermaster starter I got couldn't turn over a lawnmower engine, and three new Holley carbs have all had serious bog issues out of the box, and the list just goes on and on and on and on.
Those smaller issues didn't really bother me cuz that crap is normal, but the engine and transmission issues piled on top of those have been a bit much. I'd say nearly 60% of the new, "quality" parts I've bought haven't worked as they're suppose to. The Summit Racing returns department must hate me.
A lot of times it isn't the part breakage that gets you the most, it's the large amount of time and effort it takes to take the damn things out and put them back in. This multitude of parts failures has taken a lot of the fun out of it for me. There are times when I've just wanted to walk away from the hobby and get my life and wallet back. Hearing other people's stories is actually the one and only thing that has kept me going. So thanks for sharing everyone. Now back to the garage, I need to fix some other issues.
Chris Robinson
Old 05-25-2010, 10:15 AM
Chris --
I won't run a March anymore - it's another part (a bunch of 'em) that is laying on the shelf... they squeak and don't have an auto tensioner. Plus - I hate the cheap azz looking tensioners they come with and they rattle.
Went with a Billet Specialties unit -- LOVE IT... and the auto tensioner works great and makes for quick belt removal if needed.
So when I got the BS unit - it comes with a brand new Edelbrock water pump. They use O rings on this unit... and I put it on and all back together - fill it with water --- got a leak at the pump! WTF! Okay - all back off ('cause it must be something I did wrong!) and I notice the O ring is messed up. New O rings = reinstall - water it up -- LEAKING again... now I'm pissed... I'm a bad mechanic but not that bad... tear it all apart - check surfaces for flatness - call BS for specs on the O ring - check torque specs - VERY CAREFULLY reinstall - water her up - LEAKS LIKE A F'n PIG... Now I'm going crazy... walk away for a day or so..... this time I'm really looking a ever part - is the block cracked? The pump cracked? That's when I finally notice that the BORE on the pump is WAY OFF - skewed to one side by like a quarter of an inch! It's cutting the O ring... I had to take pictures of it to show BS - which they're probably still laughing at. They replaced the pump UPS next day air... They are a good company.
Old 05-25-2010, 10:36 AM
Damn Chris, you've had more than your fair share. I have a 3000 page build thread with all the bugs I've tackled. Lately I've been telling people, "'
Do you think the C6 Corvette was perfect after it's first test drive?" You take a bunch of bastard parts and slap it together and it's time to start working bugs out. I'm still working bugs out. I just changed over to a 1" master cylinder in hopes of less pedal travel on the race track. I haven't driven the car but it may make the brakes intolerable.
Old 05-25-2010, 10:45 AM
chr2002ca's Avatar
Hey Greg. That's what I'm talking about right there. A simple and perfect example. A company like Edelbrock f'ing up a water pump badly like that and letting it ship. And you get to have all the fun at their expense. Water pumps are pain to replace with everything that bolts to them and the lovely mess that goes with the coolant. Now, take something like that and apply it to the whole engine or a transmission, and you get reasoning and accuracy behind the title of this thread.
Next time my car starts ticking at an event and you see me walking away from it with a smile of great satisfaction on my face, I'd start running, because it's probably a bomb I placed in it.
And nice to finally meet you at RTTC!
Chris Robinson
Old 05-25-2010, 10:48 AM
chr2002ca's Avatar
Hey Todd,
Yes, your build thread and sharing of all your experiences has always been a good source of energy for me while I've been working through my own issues, and continue to do so.
I look forward to seeing you again in a few weeks for the road trip.
Chris Robinson
Old 05-25-2010, 11:13 AM
Less than 2 weeks.
