Old 12-16-2005, 11:45 PM
awr68's Avatar
awr68 awr68 is offline
When I test fit mine I had no front sheet metal on but did have the engine in, and didn't think it was too difficult...although a second set of hands would be nice while you mount the rack itself...get a friend to help and you will have a good time all the way threw!!
Tony
'68 Camaro
Old 12-16-2005, 11:48 PM
awr68's Avatar
Originally Posted by CamaroGbg
Bytheway, Anthony what happend to your website?
It dosenīt work. Not for me anyway
It's been down since my last computer rebuild...sorry! I know I need to get it back online, just never take the time.
Tony
'68 Camaro
Old 01-06-2006, 02:33 AM
CamaroGbg's Avatar
CamaroGbg CamaroGbg is offline
Any new inputs on the rack and pinion?
Old 01-07-2006, 09:16 AM
awr68's Avatar
I'll give Dan a call and see when they expect to take the shake down run...
Tony
'68 Camaro
Old 03-28-2006, 06:51 AM
CamaroGbg's Avatar
I finally got my Unisteer rack and pinion and it looks really good!!!
I have installed it and everything fits like a glove
Canīt wait until i have the chance to drive it!!!!!!
Old 03-30-2006, 09:05 PM
awr68's Avatar
Dan recently finished and drove the customers car, he said even without an alignment their was a huge improvement in the steering, handeling, and the scary bump steer was gone...I beleive they replaced a Steeroids rack.
He also added Global West control arms. With these two bolt on's the car now drives WAY better and has great road feel...he was very pleased with the parts...so much they are installing another Unisteer rack on another camaro that's in the shop!
Can't wait to drive mine!!!
Tony
'68 Camaro
Old 04-01-2006, 10:51 AM
novapwr's Avatar
novapwr novapwr is offline
Originally Posted by mstennes
I put one on last summer and love it!!! I cant beleve how much more prescise the car is. Yes I too drive it like I stole it and them some. I did have to add another Borgsen joint to clear my headers but that was no big deal. I will tell you though dont try to install it unless you have a lift or the fron clip off with the engine removed as it took us about a day and it was nice being able to stand under the car. If you want any other info just post and I will answer your questions.
Mike
Mike,
Do you have any pictures of the linkage setup with the extra joint? I had mine working properly but switched to some new Hooker super comps and now need to alter the linkage. Not sure what to order yet because I am not quite sure of where to run the new linkage setup. Thanks, Dave
Old 04-02-2006, 01:03 PM
CamaroGbg's Avatar
Originally Posted by novapwr
Mike,
Check out Unisteers linkage
http://www.unisteer.com/product.php?...cat=255&page=1
I belive you mount it where the steeringbox mountingholes in the subframe.
Old 04-02-2006, 04:22 PM
You guys are paying 800 bones for that? Seems like a lot of money for minimal gain in steering feel. You can get the same feel out of todays steering boxes for a bunch less. Might want to look at Lee Engineering's new 670 box. Same valve technology as rack and pinion, plus better response, and tighter tolerances.
Tyler
Old 04-11-2006, 11:46 PM
ilovefirstgens's Avatar
ilovefirstgens ilovefirstgens is offline
Well this has not been posted and i figure this thread is a good place to put it.
I installed the unisteer rack, and was using the ats engine plates on my ls1 and there are BAD interferance problems. The reason its bad is the bottom of the engine block and oil pan want to occupy the same space, after a bit of grinding i thing im safe however dont know until the engine is started up. i had to grind on a oil pan bolt and the block as well as both banjo fittings themselves
Brian
'68 camaro
