Old 07-24-2010, 06:42 PM
johnnymac46's Avatar
johnnymac46 johnnymac46 is offline
Default Air Compressor?????
I am shopping for an air compressor, however I need something fairly small in size(60Gal). I could do a 90Gal but that is space I need. Its going in my ONE car garage, which also houses my 68 Camaro.
I dont want to spend my unborn childrens college funds on it. I would like to keep the price around or below 1000
I have been looking around on Northern tool, Homedepot, and other similar places. Im not sure on what CFM I will need for most Air tools.
Anything recommendations come to mind?
Just to show you what im working with here......
there is a couple inches i can use behind the car for the compressor
Old 07-25-2010, 10:18 AM
JamesJ JamesJ is offline
Do you have any of your air tools yet? The CFM they use will/should be listed...
I would just get something like this. It can run anything you need and with just you using it then 33 gallon is plenty of reserve.
http://www.sears.com/shc/s/p_10153_1...&blockType=G24
James J.
Old 07-25-2010, 10:35 AM
You want a 5hp unit and are looking for at least 14 CFM at 90PSI. Even that will not keep up with a air grinder, but will be close. 20+ CFM would be great but your looking for something beigger then a house unit then or a screw compressor $$$$$$$$$$$
Frank Serafine
Old 07-25-2010, 03:06 PM
elitecustombody's Avatar
Eaton compressors are the best bang for the $$, they have different versions,best part is they run at low RPM's ,which means long life and very low noise
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 07-25-2010, 03:16 PM
can anyone tell me what the difference between single phase, 2 phase and 3 phase is? and what the different stages mean?
Old 07-25-2010, 03:41 PM
I am thinking something like this:
http://www.eatoncompressor.com/catal...747/172993.htm
I will be using grinders, sanders, air hammers, and doing some painting probably only primer and smaller things like firewall and Jams and leave the body to the for the Pros
