Old 07-26-2010, 08:20 PM
marks914's Avatar
marks914 marks914 is offline
Regular User
Default New Vintage introduces New Performance Line instruments
New Vintage is finally announcing the release of the new Performance line of instruments.
The 6 gauge kits come in standard 5” and 3-3/8” speedo and tachs with 2-1/16” fuel, volts, temp and pressure. Each kit includes a matching GM style 0-90 ohm fuel sender or s standard 240-33 gauge with matching adjustable sender.
Each kit includes everything to install including a GM speedo sender.
These kits will be rolling out over the coming weeks. Why pay more for less? The competition expects you to.
These sets are made 100% in the USA and feature:
Glass, lens-No scratch able plastic
Titanium bezels
Easy-plug Packard connectors with color-coded harness for simple wiring
Full electronic, air-core movement
Push-to-calibrate function. Push a button , drive a mile, push it again, and you’re done! No DIP switches or calculations.
Hourmeter: Really know how many hours your engine has been running with the hour meter function. Just install a ground-on switch
As always, our gauge kits include EVERYTHING required to install:
Sealed Packard connectors with 12” of color-coded wiring where required
GM style electronic speedometer sender
Momentary push button switch
Detailed, clear instructions
Oil pressure sending unit
Water temperature sending unit
Fuel level sending unit-standard--OR GM fuel gauge
Mounting hardware
Sender bushings
Why stop there, New Vintage also does custom work, why not ask about custom dials, lighting, whatever you need.
Enough of the talk, here are some pics:
3-3/8" kits:
5" kits:
Thanks for looking
Mark
www.newvintageusa.com
