Old 08-15-2010, 10:09 PM
DFRESH's Avatar
DFRESH DFRESH is offline
On the stock sub, is the reason for moving to the rack to get the outer tie rod ends away from the wheel? Wondering if you have to switch to different steering arms when you go to the rack. My outers are very close to my wheels (19 x 8's) now, no way I could go wider unless I was able to gain clearance by going up with the outer tie rod ends (shorter steering arms on the spindles) which would put them inside the wheel (from the back side of course). These are Speedtech (ATS) Spindles which have, I believe, a one inch drop or more drop. I'm planning on the Speedtech Sub myself since I have all their stuff for the front now and it works absolutely amazing. I just want to get a bigger tire under there at some point. Just wondering if I could get by for now with a rack in order to stuff a larger tire under it.
Old 08-17-2010, 08:48 AM
FreddieCougar's Avatar
FreddieCougar FreddieCougar is offline
You could get a rack now, but it would not fit our sub....
Tim McCain
[email protected]
instagram - timdrawscars
Old 08-17-2010, 07:45 PM
DFRESH's Avatar
Tim, my wallet thanks you. I'll just hold off until I get your subframe---planning to install it when the new motor goes in the car----and the hits just keep on coming.
Doug
Old 11-06-2010, 11:03 PM
wrighton wrighton is offline
After all this time I am still on the fence. On
1) Speed tech road assault package with AFX Spindles. 2,800.00 with stock subframe.
What is the wides wheel and tire combo I can fit for 69 camaro
or 2). Complete subframe with spindles. 5,800.00.
The first choice leaves room for wheels tires brakes. Roller.
Old 11-07-2010, 06:13 AM
Option1 is my choice..... Plus if you really want to you can notch the Frame for 9.5 inch wheels look up Lance-W he has several threads on it..
Old 11-07-2010, 06:41 PM
Blake Foster's Avatar
just a confirmation it you are planning on using the Unisteer Rack it WILL fit both the stock sub as well as the Speedtech Sub frame.
Blake Foster
www.speedtechperformance.com
Old 11-07-2010, 06:48 PM
Originally Posted by Roadrage David View Post
Its about time these ""afthermarket"" companys, wil divelop stuff for the pontiac engine mill insted of ""ALWAYS"" think on chevy engine blocks only. Pontiac hase a there factory block , but also 4 ""afthermarked"" blocks and more then 10 diferend aluminum heads to choose from!!.
A serius wake up call is called for , There is also no rack and pinion for pontiac powers cars, yet there are plenty brands making them for chevy!! shearing that marked.
One of these companys should step up!!.. funny thing is speed tech is advertizing a afthermarked ""firebird and transam subframe"", yet it sais no modifications hase been done to ecsept the pontiac engine. how lame is that!!!!!
David we have had one or two customers install Pontiac engines in the Speedtech sub frame. they made their own motor mounts and the rack and pinion did fit. one is a member on here.
the reasn the after market us included haven't done a pontiac is that there are just not enough people doing the swap.
i don't think a "wake up call" is needed the customers need to be there to pay for the R&D
Blake Foster
Old 11-07-2010, 06:50 PM
the steering that are used with the Unisteer Rack are very short, and do provide room for wheels. my Nova has 18x9.5 with 6.5 BS wheels and no issues, even with the drop which by the way is 7/8 of an inch ove the stock spindle.
Blake Foster
