Old 08-23-2010, 05:47 PM
70rs's Avatar
70rs 70rs is offline
Looks like a great project. I'm looking forward to seeing this one come together.
Eric
Old 08-24-2010, 04:37 PM
G-Body's Avatar
G-Body G-Body is offline
I like the offset of the front wheels gives it the big and litttle wheel look.
Old 08-24-2010, 07:02 PM
Northeast Rod Run's Avatar
Northeast Rod Run Northeast Rod Run is offline
Originally Posted by awr68 View Post
Very cool! Can't wait the see a rendering of this one!!
X2
TJ Ragucci
http://www.northeastrodrun.com/
Old 08-24-2010, 10:10 PM
Steve1968LS2's Avatar
Very cool guys!!
Man, if they had stuff like this years ago I would have so gone this route.. can't wait to see it in person.
Old 08-31-2010, 09:27 AM
Roadster Shop's Avatar
Supporting Vendor
RoadsterShop.com
Steve, all you have to do is build another car! Totally worth it in my opinion
www.roadstershop.com
Old 08-31-2010, 05:44 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
Any updates on this bad boy??
Old 01-16-2011, 06:24 PM
Derek Miller's Avatar
Derek Miller Derek Miller is offline
Really like the looks of the new frame. Does your setup require the existing frame rails to be completely cut out on a first gen camaro? Is the frame welded to the body or is it somehow bolted to it?
Thanks,
"Anything Worth Doing, Is Worth Overdoing."
Old 01-17-2011, 07:58 AM
Jay Hilliard's Avatar
It looks like your chassis uses the same mounting points for stock sub at firewall and close to crossmember. Where/How does it fasten at the rear?
Nice build.
Jay
Old 01-17-2011, 04:49 PM
Supporting Vendor
RoadsterShop.com
The chassis does use all of the same front subframe mounts. This eases the installation so you do not have to fab new mounts, or locate where these would need to go.
The rear requires you to remove the sub rails up to the last 6" or so. (I'm on the road and don't have the exact measurement) Then the rear of the frame will bolt to the end of the sub rail where the spring hanger user to bolt in place. We put 2 additional body mounts in the main section of the car to secure everything in place. The mounts are in the frame, you would just have to drill the corresponding hole in the floor and bolt it in place.
Here are 2 pics of the rear mount during the mock up phase. They were tacked into place at the time of this picture. The 1x1 square tube further forward was also a temporary piece for the mock up phase.
Old 01-17-2011, 06:22 PM
Thanks for the pictures. Do you know roughly how much hp this frame will handle?
