Old 09-29-2010, 01:52 PM
Denvervet's Avatar
Denvervet Denvervet is offline
nother question. Is the fuel sending unit in this module compatible with a 90 ohm autometer fuel gauge? I think there are two versions of gauge senders and need to know about this factory type.
68 camaro, 572, tko
Old 09-29-2010, 02:43 PM
CarlC CarlC is offline
0-90 and 33-240 ohm sending units are available.
The 0-90 ohm will be a standard float-arm sending unit that mounts via a flange on the manifold plate of the tank. A similar 33-240 ohm sending unit is also available. The OE type that attaches to the module is 33-240 ohm and requires a longer flat section on the lower/forward section of the tank.
http:www.vaporworx.com
Old 09-29-2010, 08:45 PM
Denvervet's Avatar
So we'd need to purchase a sending unit and fuel pressure regulator in addition to the pump module?
68 camaro, 572, tko
Old 09-30-2010, 09:58 AM
Denvervet's Avatar
No need to reply....found the extended description over on another web site
68 camaro, 572, tko
Old 10-01-2010, 03:35 PM
turbo67camaro turbo67camaro is offline
Are stainless straps included or extra?
Old 10-01-2010, 08:04 PM
You will need to talk about that with Hector at Ricks.
Whoops. Sorry Frank, this should have been routed to you.
Old 10-01-2010, 08:41 PM
Straps are included on all our tank sales.
Frank Serafine
